Illamy lg wd-1238c washing mashine is not working and is displaying a cl fault code.
    Guru:
  • 500 Answers
CL Means Child Lock.
You may have put it on by accident.
Look for a child's face with to lines pointing to 2 buttons on your Facial Panel.
Press these to buttons for 3 to 5 seconds and the Child Lock will deactivate.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up, and a testimonial will do nicely :-)
Posted on Apr 02, 2011
I have a LG WD 1238C Front Loader Washing Machine and the display has a CL on it.
Remove power for some time , allow the power to drain off the memory and see if the display is clear. If not hold the start button and switch on power. Check the inlet and drain filter , free water flow, if not remove and clean.
Nov 01, 2013 | LG WD-1280FHD Front Load Washer
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
I have a LG Front loader machine, WD-10485TP displaying CL error code. Please help.
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it. It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
If problem remains unresolved, revert and i would tell you few more methods.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 22, 2011 | LG WD-1280FHD Front Load Washer
I didnt get a users manual with my lg WD-1238c front load washing machine and only no how to use the quick wash cycle, where can i get the information i need to use it?
go to LG's website and start there. If it's not available ther, Google LG (model) user manual. There you will find plenty of links to websites that offer manuals.
May 08, 2011 | LG Washing Machines
Hi my LG washing machine (WD-80485NP) has stopped working since this morning. The error code shown is: CL Any idea what that means?
The "Cl" fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
Mar 13, 2011 | Washing Machines
When i plug washer in,cl displays on screen and machine will not turn on.
There is no "cl" error code for the LG WD-3245RHD. Your display unit may be bad, because there is a "cE" error code, which indicates an overload in the motor, and the suggestions in the manual are to close the tap, unplug the machine and call a service technician. So far, I have been unable to find anyone that will adequately service any LG appliance. It seems they think of their products as disposable, not repairable.
Oct 29, 2010 | LG WD-3245 Front Load Washer / Dryer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Front Loader LG Inverter 7.5kg WD-1238C
CL is about the Child Lock which is done by pressing both the buttons together. To release the same do press both the buttons under the display simultaniously.
Dec 02, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
