My sx-910a headset goes in play mode in stead of pair mode even when there is no bleutooth device around. I have already charged it.
CLUEPATEL
  • 138 Answers
SOURCE: To connect N95 with bleutooth headset LG HBM-550
1st switch on bluetooth for both devices!
2nd go to your bluetooth menu in your phone
3rd click on pair devices
make sure that your phone is visible to other bluetooth device
4th select the device and click on pair devices!
its done!
Posted on Dec 08, 2007
SOURCE: Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Posted on Sep 14, 2008
jsinex2421
  • 62 Answers
SOURCE: pairing mode for headset with PS3
On your PS3 XMB menu. Go to settings. Scroll down to accesories. Then click on manage bluetooth devices. There you will find the autodetect for the bluetooth headset. While the bluetooth headset is off, press and hold th on button until the LED stays on. The quickly use the PS3 to detect the blue tooth. It will ask for a pin to pair the units up. The pin is four zero's.
Posted on Jan 10, 2009
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Posted on Mar 09, 2009
  • 23 Answers
SOURCE: my h710 will not go into pairing mode. I have
Make sure your phone is in discover as well. Also make sure your holding down all 3 buttons at the same time for at least 10 sec. then it should go into discovery.it will blink then go solid.
Posted on Aug 19, 2009
What is the pass key code to pair lg tone pro HBS 750 to my ps3?
1. You need to charge your headset to full capacity using the charger supplied with it.
2. Disconnect it i.e. your headset from the charging source.
3. Press and hold the "Call/Send" button located on the front of the headset for like 5 seconds to activate pairing mode.
4. You should notice an indicator light begin to flash. Your headset is in pairing mode already.
5. By now, you must have had the bluetooth on your PS3 on.
6. Have both devices pair with each other.
LG headsets use a pairing passkey of four zeros ("0000").
Apr 15, 2015 | LG Electronics HBS-750 TONE PRO Wireless...
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
I have a h700 bluethooth and dont have a manual. what color should the light be when connecting to the phone, in use, and charging.
The indicator turns red when charging and turns green when fully charged. The headset will flash in purple when it is in discovery mode (mode where it is looking for a device to be paired with it). If it has already been paired with a device it is blue and then flashes blue when it is paired. The link for the manual is below. http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Jul 23, 2011 | Motorola Mobility H700 Wireless Headset
How do i set up my hs50 b.t. on my boost mobile phone
Please try in this way, with the headset turned off, press and hold the call botton for 6 to 10 seconds until the blue light indicator turns on and remains steadly lit (pairing mode), then set your phone to look for devices, the headset should be found as Motorola HS50 (handsfree profile), select it and enter the password 0000 (four zeroes), this will pair (bond) the headset with your phone.
Feb 16, 2011 | Radio Communications
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
How to connect my motorola H710 bluetooth with my mobile
You must put it in pairing mode. If it has not been paired to other phones, just open its boom. After a while the indicator LED will be steady blue. Otherwise, if it has been previously paired to other devices, make sure the bluetooth radio of those devices are turned off. Then, open the boom and, as the headset won't find any devices already paired around, it will enter pairing mode automatically (again, indicated by the steady blue LED).
Once your headset is in pairing mode, make your phone's bluetooth application search for new devices. After a while, the H710 will show on screen. Select it and command it to proceed. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, you can download it from this location;
Cheers! Carlos
May 09, 2010 | Motorola Mobility H710 Bluetooth Headset
My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
Jan 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
Pairing Mode
I had the same problem..tried to pair it for hours but could not get it to do it till the battery ran out and i had to recharge it..
I later found out that it was not pairing because the batteries were low. If the battery gets below a certain level it will not pair the headset because it's trying to save energy. anyways after a full charge it paired just fine...hope this help you guys....
Jan 27, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Tried paring Motorola BT H700 to my phone when it has already been paired to another phone
With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect.
Jan 05, 2008 | Motorola Mobility H700 Wireless Headset
82 people viewed this question
 Grubhead
Grubhead
