Question about Hardware & Accessories
Have a new property in France and the Developer does not seem to have any instructions for the timer which works our radiators.
  • 3,289 Answers
Hi Julie -
I think you might mean thermostats instead of timers - but it is possible that you have timers on the system as well.
There are dozens and dozens of manufacturers of thermostats. Each manufacturer can make dozens and dozens of models for more types of heating systems than you've ever seen. In order for anyone to get you the help you're looking for - you're going need you to provide the timer or thermostat manufacturer's name AND model number.
Posted on Apr 02, 2011
    Scholar:
  • 133 Answers
Please give us the make, model and a brief description of what it looks like. I'll try to find it for you.
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Water Heater Timers Save Money
Dec 11, 2014 | Hardware & Accessories
Maintenance require code vc
The VC code on a sharp mx-2700 is the cyan developer has reached its maintenance cycle of 60,000 copies. to clear this code enter sim mode #, *, C, * then 24-5 to clear dv count.
Jan 28, 2014 | Sharp MX-2700N Color Copier
How to change developer beads
I have the complete 9 page instructions with images if you want I can e-mail them to you. Here is a snippet explaining just the portion of the beads. (email me at itsallnoise2me@gmail.com for complete instructions). Also, if you purchase the developer beads from iteminc.com they will include the instructions " 1. Place the developer housing assembly (new or used) to be recharged on a drop cloth. Caution During this procedure, the developer housing assembly must be kept level at all times. To prevent toner spillage, it is recommended that the developer housing assembly be fully supported level by laying it on something like a large piece of cloth, paper towels or styrofoam hollowed out for the developer housing assembly to lie on. If new, remove the protective cover over the magnetic roller. Do not touch the magnetic roller. Note The wires are routed under and behind the right snap tab. 2. Release the snap tabs at each end of the developer housing assembly and remove the assembly cover. 3. Agitate the package of developer mix and then cut it open. Carefully pour the entire contents of developer mix as evenly as possible over the two augers. Do not let the developer mix accumulate heavily on the roller. Keep the developer housing assembly level. 4. Reinstall the cover making sure that the rear tabs are all engaged in their respective slots while positioning the wire harness under the snap tab. Press firmly until you hear a positive "snap" sound for each tab indicating each snap tab is securely fastened. 5. Tear off the ATC sensor perforated tag. Do NOT remove the ATC sensor label from the developer housing.Peel off the protective backing, and adhere the label to the appropriate or corresponding Imaging Unit Plate. Make sure the ATC sensor tag label can be located if needed later. 6. Record the number for entering into NVRAM in the next step. 7. Perform the ATC Sensor Setup procedure."
Sep 13, 2011 | Xerox Phaser 7750DN Laser Printer
I have lost the instructions for my boiler and I have seen that the timer is a Grassling timer, i don't know when it is on or off, it might not even work as the radiators seem to stay hot whatevr I do.
Without knowing which Grasslin timer you have, I cannot offer specific instructions:
Find Grasslin timers and manuals at following link:
http://www.intermatic.com/products/grasslin.aspx
I am familiar with Grasslin timers, and you can add a comment with specific question and I will respond.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 02, 2011 | Intermatic Hardware & Accessories
Hi i have a new DeLonghi Dragon 3 heater. The timer seems to work opposite to your instructions - i.e. the instructions indicate that the notches must be pushed to the outer ring to indicate the operating...
This is from the instruction manual online:
To set the heating periods proceed in the following manner:
- Check the time by your watch. Supposing it is 10.00 a.m. turn the numbered dial of the
time-clock in a clockwise direction until the number 10 coincides with the reference mark s
on the time-clock. Set the time period during which you wish the appliance to work by
pushing the notches towards the centre. Each notch corresponds to a period of 15 minutes.
At this point sections will be visible corresponding to the working periods.
Set in this way the radiator will function automatically every day during the set period.
(Important: the plug must remain connected to power supply).
- To change the programmed time period, just bring back the black notches to their original
position and set the new working periods required.
- If you wish the appliance to function without programmed working periods push all the notches
towards the centre. In this case, to turn the appliance off totally the plug must be pulled
out apart from switching off, so as to avoid unnecessary working of the timer.
Jan 29, 2011 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Sharp AR-208D copier needs developer - how to add?
Set-up for this copier sure isn't well-documented. We just got ours working today, found out how to add the toner by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
Apr 02, 2009 | Sharp AR-208D Printer
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
