Question about Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue
How do I find the manual for the Kenmore Progressive Bagless Inteliclean Vacuum, purple?
3 Suggested Answers
SOURCE: Kenmore Progressive vacuum clogs continuosly
Try taking the bottom off and this will reveal if you have something clogging up the flexible tube. Just did this last night there was a ton of junk clogging the tube and I cleaned it all out and put it back together now it works fine. Seems like with the design of the vacuum this will always be a problem.
Posted on Dec 30, 2009
joeguest2
  • 2080 Answers
SOURCE: need owners manual for kenmore progressive vacuum cleaner model 116
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0412323.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Posted on Nov 29, 2011
Caught fridge of a blanket in vaccum. Turned off and remove object. Now beater bar does turn. How to fix?
Sounds like the belt either just slipped off, or is broken.
It's normal when the beater gets jammed.
Can you spin the beater easily?
Jun 24, 2011 | Kenmore Progressive Upright Vacuum with...
I sucked in a sock or something. How do I get at it?
remove the lower floor unit plate,, and use a wire coat hanger to fish out the ' sock '. if it is way up the hose - then you might need to remove the hose from the unit and try and work out the blockage using your wire or a stiff dowel.
c...
Feb 16, 2011 | Kenmore Progressive Upright Vacuum with...
We have the Kenmore progressive direct drive (bagless) and have had it for about 3 years. We have taken good care of it, and paid quite a bit for it hoping that it would last for a good long time. It has...
there has to be a clog or block somewhere - if the motor works, it should work did you try a wire coat hanger to go up in further where you cannot see?
Bets regards
Ck
Jan 15, 2011 | Kenmore Progressive Bagless Upright with...
Kenmore InteliClean 116.35923502 Two, I believe unrelated, problems. 1) The InteliClean sensor lights stay amber and red even when the machine is in the upright position and the suction line is...
I had the same problem with the amber inteliclean light continually on. I found the problem to be in the plastic housing that connects the suction hose to the back of the upright section. You have to remove three screws and gently pull the hose housing off the vacuum. Inside I found a hairy clump that was caught on the inside of the hose. The optical "dirt sensor" is just inside the fitting on the upright section. When dirt or other stuff blocks the optical path of the sensors, the amber light will illuminate. My vacuum had an uneven cut on the hose which caused a snag point for hair, dirt and debris. Once this was removed, the vacuum worked like new.
Regarding the roller, this unit has an integrated motor in the roller. I would guess that you will need to take it apart, and hopefully only clean it up. If you need bearings, that will likely be expensive.
Dec 24, 2010 | Kenmore Progressive Bagless Upright with...
Beater bar stopped working
Here is one of my Tips on the problem you are describing:
www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
If you have further questions, just let me know.
Good Luck!
Jim
Oct 10, 2010 | Kenmore Progressive Upright Vacuum with...
I have a Kenmore Progressive Upright Vacuum - Purple, and it worked just fine. I emptied the canister (like always) and put it back in place. I turned on the vacuum to it immediately shutting down (motor)...
Make sure that something didn't fall into the fan assembly in the base when the canister was removed. The motor should have an overload reset switch. Try moving the motor manually (power plug out) to make sure that it isn't bound up.
Dec 24, 2009 | Kenmore Progressive Bagless Upright with...
Dec 08, 2009 | Kenmore Progressive Bagless Upright with...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk.
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Dec 02, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue Logo
91 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
