My screen is connect to the computer whith the blue cabel and to the screen as needed. i can't see any picture and on the screen write "no signal input" what should i do?
  • 20 Answers
In the future, please list a brand and model. I must assume this is a desktop computer. If it is a laptop, I am typing this all needlessly because you need to hit the external monitor button on the laptop keyboard to switch screen or use both. I can also assume that there are no beeps and the rest of the pc appears to boot up normally, the cd lights up, the hard drive access light flickers, etc. Most desktop pc's have become cheaper in that the video is integrated into the motherboard. Before you run out and attempt to change the motherboard, if the unit is under warranty, let the manufacturer honor the warranty. If it is not, proceed in a cost effective manner. Check the monitor with another computer or a tv with an SVGA output plug. This is the cheapest an most non-invasive solution besides checking the plug to make sure it is physically plugged in. If the monitor is tests good, ground yourself by touching the metal case before you open the case while it is plugged into the wall outlet. Unplug the rest of the wires and re-seat the RAM memory chips. Since desktop computers use shared memory, it is possible for one chip to go bad or chip creep to make a bad connection. Try one last time to boot up. You do not need anything bu the power and video cable plugged in to test the video and you do not need to replace the cover yet. If it still does not boot you have a choice. Either replace the motherboard or just add a video card with it's own memory. Which video card depends on two things. Which motherboard is in the unit determines whether you need a PCI, PCI-E, AGP, AGPx2, or in simple language, how the new card will plug into the slot. You cannot put a round peg in a square hole so buying the right card will give you cheap instant gratification. Written in the motherboard in small print is the name and model number of the motherboard. All units also must have an FCC id which identifies the manufacturer. Dell, nor HP makes the actual computer parts like the motherboards. They do keep a database of drivers and a few spare parts for units under warranty. I would check the manufacturer's web site for the motherboard specifications; however, if you check the two hyperlinks above, you can look at the pictures and buy the correct video card. I personally would not change the motherboard on an older unit because too much can go wrong and the unit will work faster and better with an add in video card with it's own memory. You can go into any Best Buy or shop online with Tiger Direct and get a video card with the proper interface. Once it arrives, ground yourself once again, and consider ordering an antistatic wrist strap too. Remove one screw or use a screw driver to twist and remove the cover where the video card goes, using two hands insert firmly. Replace one screw. plug it in and enjoy.
Posted on Apr 02, 2011
Black screen and blinking blue light
blinking blue lights means the monitor is stand by.for the black screen
you should check your cabels from monitor to computer.they should be seated tight.if still no picture your videocard is proberly brooken.
it should be point out at LCD-monitors are fragile.
Apr 20, 2013 | Samsung SyncMaster S22B150N - LED monitor...
When tv is turned on, screen shows white w/ blue logo, then shows "VGA" and "no signal" on a blue screen. After a minute it turns off. We cannot get a picture. We have a Time Warner...
Right now the TV is set to accept the video signal from PC through the VGA port so when it does not see the video signal from the VGA port, the TV will go into shutdown or standby mode. You need to change the input to be where the cable box is connected to using INPUT or SOURCE button on the remote.
What kind of connection are you using to make the connection between the TV and the cable box?
Please clarify. Make and model of the TV?
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Aug 19, 2011 | Televison & Video
Hello, well I hooked up my computer to my vizio with a vga cable. At first it worked just fine, then once I tried changing the resolution for a video game, the screen went blue and says "not...
The VGA cabel has vast signal capacity. However, the computer to has as much sigal cacity. The TV also has as much signal capacity as well. The computer in this situation is providing the signals to all devices connected to the insfrusture. However, the computer has a functionality requirements mode. For exaomple, the computer blankout whenever resolution is increased is n consideration of requirng so much power supply for all displays on several powerfun screens of much high defincition capapacity. The more high definition the computer, the possibility of powering signlas to TVs of much least intensity not vise verser.
Jan 11, 2011 | Computers & Internet
NO SOUND AFTER REINSTALL COMPUTER PROBLEM WITH SOUND AND HOW TO PUT EACH CABEL IN OR OUT SYSTEM,
Can you see the Speaker Icon on your taskbar? If you are sure that there's no driver issue with your computer, then take a look at the picture below and follow the instructions; 67ef368.jpg
Green to the Speaker, Red to the Microphone and Blue for Line-In. Connect your speaker stereo jack to the Green port/plug, turn on the speaker and check with the volume.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | Yamaha YST-M15 Computer Speakers
I have no Genuine USB Cabel to Connect the Camera with PC!
Use a card reader to download your pictures to a folder you create on your desktop.
Sep 29, 2009 | Nikon Coolpix L1 Digital Camera
Ok guys i got a dbr 3475 clarion cd player now i got two wires that are power yellow and blue with white strip now i know what the speakers are` but i have this red wire don't seem to go any where i power...
hi the yellow cabel is the (12volt) the blue and white is power antena and the red cabel is also a power cabel you are supposed tho putt the yellow and red cabel tho gether and connect them tho the power in the car the red cabel is a (1volt) cabel it is tho keep the memory on the stereo
Jun 08, 2009 | Clarion DRB2475
Wired computer cable. Absence of
The blue ethernet cable should be the wired cabel they are reffering to.
Apr 13, 2009 | Belkin Computers & Internet
Connection
Hi...there,
Try Red, Green, Blue that is a sequence. settings all to 100% Have a nice day!
Feb 02, 2009 | iiyama Vision Master 404 Monitor
IN-34 Picture colours not matching
change and try
another vga cabel first because any cut inside make the same trouble.if it does not work with you you must obtain service manual befor you continue.
Jan 02, 2008 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
