Question about Cerwin Vega CLSC-6C Center Speaker
Hello, My CLSC-6C speakers make "scratching"
    Problem Solver:
  • 9 Answers
Most likely it is a rubbing voice coil in either the midrange driver or the tweeter. The only way to repair is to replace the bad driver or tweeter with a new part. Contact CV for replacement parts costs. Replacing parts in most speakers is usually easy to do if you have rudimentary tools and skills. Most connections are made with "faston" slip on/off connectors so a soldering iron is usually not needed.
Posted on Apr 02, 2011
Hey, just purchased some behringer ms 40 near field monitors and after a few hours of playing at around the 1/4 volume mark i decided to turn the bass up. As i did so the right monitor began to make a...
The setting of the volume controls bears LITTLE importance to the actual level the unit is being run at since one can send high levels INTO the units from the source. These are intended to be used in a studio for the audio engineer to listen to in a small room. They should really be no louder than a consumer BoomBox maximum.
A squeaking noise is not normal at a level such as mentioned however. You might see if the noise is from the speaker itself or possibly parts of the cabinet... Plastic parts are NOTED for squeeking and can be suitably lubricated.
Beyond that, since the units are new, you should be able to exercise your warranty.
Mar 10, 2011 | Behringer Ms40 40w Active Powered Studio...
When i switch on the system, there is a very loud noise, almost like electrical wires colliding - what could be the reason?
That is normal power up sequence for speaker... make sure your mixer is on FIRST before you fire up speakers. Another tip; turn volume levels down when you turn on so you don't damage speakers.
Feb 22, 2011 | Behringer Eurolive B212A Speaker
New Yamaha AV Receiver and Tannoy Speakers muffled weak bass only
Maybe some wire is faulty... Try to disconnect everything and connect each speaker one by one, first trying only radio tuner and then trying to connect the TV and other devices. Using that you can isolate the fault into the specific component/wire.
May 26, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
When playing on high volume the treble dissapear. I have a 2.6kw Cerwin amp. And Clsc 215 speakers. No bi- wire on my speakers. When I lower the volume the treble returnes. What is wrong???
Sounds like your overpowering the horns and the circuit breaker is tripping to prevent them from blowing. You are running more power then they can handle. You can turn down the volume or will have to purchase higher wattage horns...
Mar 24, 2010 | Cerwin Vega Cerwin-Vega CLSC-215 3-Way...
I stopped having sound coming from the speakers. I checked and we are not on mute, and the volume is turned up high.
Make sure all your connections are tight and you have power to your speakers...Then go Start>Control Panel>Sound and Hardware>Sound, after you are in here make sure that your speakers are selected as default device.
Hope this helps, pls rate
Mar 19, 2010 | Proview Computers & Internet
Noise at maximum volume
NEVER turn the volume up to maximum if you suspect there is ANY signal coming in.
Is this an academic question, or does it really bother you at normal listening levels with a signal present? What you're doing isn't very real-world.
My own excellent system has audible hash noise present when I turn the volume up to max on a dead input, but it's still less than normal ambient noise in the room so I don't worry about it.
Feb 18, 2010 | Audio Players & Recorders
On my Sony Surround Sound tuner, if I raise the volume up to a certain level (not that loud), I get a flashing sign ''protect'' and the sound to the speakers are cut.
Sony has protection in these receivers for two main reasons.
1 - Checking for DC voltages on the outputs to speakers. Not your particular problem.
2 - Excessive current being drawn from receiver on one or more of the speakers.
Number 2 should be your starting point in finding a solution. Put the volume level on Medium - 35 to 40 on the front panel. Now listen to all you speakers in turn. Any scratching noise will indicate a defective speaker. Remove this speaker from the receiver output and check again if the set goes into protection on high volume.
If you could not find any strange noises on the speakers, remove them one by one and test the set on high volume.
Never - attempt to disengage the protection on this amplifier. The only times we have found the amplifier to be defective with this protection error, it has done so no matter the volume level. Therefore I believe your problem to be a speaker or speakers.
Sep 13, 2009 | Sony Audio Players & Recorders
Iball speakers making irritating noise
please try better speakers better ohms orhigher wattage. improper speakers not for pc's or laptop will cause the hum..
Nov 29, 2008 | Audio Players & Recorders
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
62 in LCD mitsubishi
Not too sure about the thumping, possibly the cabinet expanding and/or contracting with heat, the lack of and weather change. But the scratching sound could very well be the HV discharge. So, not being able to hear it myself, I would suspect that yes it's probably normal.
Bill
Nov 20, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Cerwin Vega CLSC-6C Center Speaker Logo
262 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
