Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water runs into tub, but does not fill. - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
    Habit-Forming:
    New Friend:
  • 77 Answers
Is it drains out if so the out let washer/solnoid not is not functioning
Posted on Mar 04, 2015
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: tub fills with water without running the washing machine
This is often caused by a water inlet valve that is leaking by, or a pressure switch malfunction. The following link explains how to troubleshoot and repair:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
This is a very simple and inexpensive repair. If parts are required, you can order on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Use whatever parts source you like, but these sites offer great service with competitive pricing, so shop and compare. The first three sites on the list also offer helpful exploded view parts illustrations to help you locate and properly identify the parts you need. If you have questions, please let me know. I hope this helps you.
Posted on Feb 06, 2010
Washer will not hold water
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Jan 12, 2010 | Washing Machines
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
My washer will not spin and can only fill tub on small loads cause water will run out
does the water keep running and it keeps draining the water? if so your drain hose needs to be higher than the highest water level in the tub or it will drain as it fills.
Aug 31, 2009 | Washing Machines
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
Keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
Apr 24, 2009 | Washing Machines
Tub fills only 1/2 full but water keeps running as if the tub is not full. If the water level is set to 1/2 or less, tub fills 1/2 full and begins to cycle. The water is running into the tub but not...
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe.
Also make sure the drain hose is not going too far down into the drain pipe.
You may be getting a siphon effect.
Feb 20, 2009 | Admiral AAV7000A
Water filling tub
You need a new cold inlet valve fitting.
Dec 08, 2008 | Kenmore 44042 Front Load Washer
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Water runs, but tub does not fill on whirlpool washer
Well...if the water is running, the tub is not filling, and you don't have water all over the floor, your drain hose is installed too deep in the drain pipe, or just installed too low, so that the water is simply running out of the machine and out the drain hose.
Sep 14, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
82 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
