Question about Futaba GY401 Gyro withSmm Technology
My gy401 work great until i unplug the battery
Wont start or stay running unless battery charger is on it
some four wheelers require a battery to run correctly. sounds like you need a new one.
Mar 26, 2014 | ATVs
Dell wont turn on
unplug ram and replug
Feb 20, 2014 | Computers & Internet
Throttle potion sensor
check vaccum leaks around top of engine . check senser plug for air intake. it sounds like something is unpluged
Sep 05, 2017 | 2002 Hyundai Santa Fe
My battery is completely killed every 3 days after general operation . I've replaced 3 batteries since November 27th and it gets drained while driving . I had the alternator checked and it is great , tried...
Make sure the alternator is still connected to the battery. Should be a smaller wire running from the alternator to the positive post of the battery. There may also be a fuse for the alternator, check that.Your battery is not charging.
Dec 04, 2010 | 1999 Dodge Durango
My Emerson CKA1000 clock radio worked great for years, but now it eats the battery back up, battery will go dead in a month or so and if I set the alarm for radio it will show the 20 ne message when the...
Sounds like the main power supply may have gone bad and you are strictly running off the battery. This is why it works fine for a while when you install a new battery, that is until that battery drains and gets too low. The radio won't play because it is preserving battery life. I bet you could unplug it from the wall and would get the same results. You essentially have a battery powered clock right now. To test this theory simply remove the battery, plug the clock up and see if it comes on. My guess is it will only work with the battery installed.
Jul 23, 2010 | Emerson CKA1000 Clock Radio
NB 90 will not power on after turning off unless i unplug it.
yes a little groove under to big batteries. AA i think
May 14, 2010 | JVC RV-B90 Boombox
Garmin Nuvi 265WT says loading loader
I left my GPS on and unplugged over night (I upgraded at 6pm) until the battery died. When I plugged it in to charge this morning it worked just fine with no problems.
Jun 06, 2009 | Garmin Nuvi 255 GPS Receiver
Ty0ping i0n add0it0ional0 0 characters
changed batteris and that worked great. Until this am. Came in and same problem. switched batteries back but no fix. I am sure new fresh batteries each day can't be the solution! Anyone have any ideas
Dec 16, 2008 | Logitech Cordless Desktop EX110
Futaba GY401 Gyro withSmm Technology Logo
27 people viewed this question
Top Futaba Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Futaba Toy Expert? Answer questions, earn points and help others
