Question about Galaxy Radios DX-2517 CB Radio
Where do you adjust the signal meter ? the meter works but signals are real low.
    Habit-Forming:
    New Friend:
  • 65 Answers
I know its a vr. Use a screwdriver small and dont force it...most radio are vr1.
Posted on Mar 05, 2015
    Novelist:
  • 146 Answers
Http://www.cbtricks.com/radios/galaxy/dx2517_mosfet/dx2517_mosfet_trans_adj.htm
RF Meter
I'm not sure that is what you want to do. It seems like you are really asking to improve you receive or sensitize it. That may require some specialized equipment and if your thinking of giving it a go you might not like the end results.
Posted on Mar 04, 2015
Me esta dando un codico con el escaner 1709
english please. 03 suz aerio
no engine option stated, nor tranmission.?
DTC P1709 is a suzuki only factory code P1 mean that.
so only suzuki books work for that
I log in to alldata
and see
Trouble Code:P1709
Engine Coolant Temperature And Barometric Pressure Signal Circuit Malfunction
Trouble Code Conditions:
Too long high signal of pulse signal from ECM to TCM continues to be out of specification. or Too long low signal of pulse signal from ECM to TCM continues to be out of specification. or Too long or short low signal of pulse signal from ECM to TCM is detected in continuous 8 pulse.
Possible Causes: TCM errors. check
only a real FSM will help here.
get one. or get service at Suzuki.
Jan 10, 2014 | 2003 Suzuki Aerio
I need a honda car code , i can't turn on my radio
service manual.
Code Description Possible Cause
0 ECU / ECU signal No signal to ECU
1 Oxygen sensor circuit Oxygen sensor or circuit, ECU
2 Oxygen sensor circuit Oxygen sensor or circuit, ECU
3 MAP sensor circuit Map sensor circuit
4 CKP sensor / engine speed (RPM) Crank angle sensor or circuit, ECU
sensor
5 MAP sensor circuit MAP sensor or circuit, mechanical
problem
6 ECT sensor circuit ECT sensor or circuit, automatic
transaxle control unit
7 TPS / Angle Sensor TPS sensor or circuit, automatic
8 CKP sensor / engine speed (RPM) Crank angle sensor or circuit, ECU
sensor
9 CMP sensor CMP sensor or circuit
10 IAT sensor IAT sensor or circuit
11 Idle Mixture Adjuster Sensor Idle mixture adjuster sensor or
circuit
12 EGR system fault No EGR action, faulty EGR valve
13 BARO sensor circuit BARO sensor or circuit
14 Idle Air Control valve circuit / ECU Open or shorted out ignition signal
circuit / No signal to ECU
15 Ignition Output signal Open or shorted ignition output
signal circuit
16 Fuel Injector Circuit Open or shorted fuel injector
circuit
17 VSS circuit VSS sensor or circuit
18 Ignition Timing Adjuster Open or shorted signal circuit
19 A/T Lock-up control solenoid Open or shorted signal circuit,
Lock-up control solenoid lock-up solenoid
20 Electrical Load Detector / Sensor Electrical load detector or circuit
Honda/Acura
Fault Code Definitions (21 - 59)
Chapter 3 22
21 Spool Solenoid Valve Open or shorted signal circuit,
spool solenoid valve
22 Valve Timing Electronic Oil Open or shorted signal circuit,
pressure switch valve timing oil pressure switch
23 Knock sensor circuit Knock sensor or circuit
30 AT / ECU communication signal A AT control unit, ECU
31 AT / ECU communication signal B AT control unit, ECU
35 Traction control / ECU / signal Traction control module, ECU
36 Traction control / ECU / signal Traction control module, ECU
41 Oxygen sensor heater - left side Oxygen sensor / heater or circuit
42 Oxygen sensor heater - right side Oxygen sensor / heater or circuit
43 Fuel Supply system - left side Oxygen sensor or circuit, fuel
system
44 Fuel Supply system - right side Oxygen sensor or circuit, fuel
system
45 Fuel metering - left side Injector control circuit, incorrect
fuel metering
46 Fuel metering - right side Injector control circuit, incorrect
fuel metering
48 Heated oxygen sensor Oxygen sensor or circuit
53 Right Knock Sensor Right knock sensor or circuit
54 CKP sensor 2 CKP sensor 2 or circuit
59 CMP sensor 2 CMP sensor 2 or circuit
Dec 28, 2010 | 1994 Honda Accord
2002 Corvette. Turn signals just started to not work at all. Also have interference in radio when turn signals are on. 4-way flashers work OK.
It sounds like you have a wiring problem. get a volt meter and locate the fuse box. First check your fuses. If everything looks ok there take your volt meter set on DC and check each fuse if one of them reads low or doesnt read at all then you have a wiring problem.
Sep 27, 2010 | 2002 Chevrolet Corvette
Trying to install an English freesat box in Spain is this possible as the the signal says no signal strength on the screen whats the answer anybody help us The model number is DTR2520 it is a brand new...
is a dish position , not in position, need a special signal meter, to tune the right signal, and normaly must replace the dish head, old models has low digital output signal. you need a specialist to tune the dish position and get the proper compatible dish head. for your receiver.
Feb 16, 2010 | Audio Players & Recorders
I cannot get the rca speaker wires to produce sound. i can get sound out of the hard wire speaker wires
the rca speaker hook ups are there to carry a signal to an amp and the amp to put a signal out to your speakers so with that being said you will not get sound out of them due to the fact that it carries a real real low power signal
Jan 23, 2010 | Clarion XMD3
Jaguar xj6 4.0 1990. showing fault code fuel 14, fail 14. what does this code mean ?
2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Nov 09, 2009 | 1990 Jaguar XJ6
Iam about 30 meters from where i get my signal
To improve signal performance, change the wireless channel on the wireless router.
Aug 07, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Lazy signal needle
Probably NOT the potentiometer that assists the meter. I would suspect a abad needle in the meter. I'd see if you can get to the adjuster screw on the meters front. Many times it's hard or impossible to adjust due to the way it's mounted.
Jan 12, 2009 | Midland 4001 40-Channels Base CB Radio
Radio Communications Logo
144 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
