Question about Sport & Outdoor - Others
Hi there, we have recently moved house, the palm tree (according to the previous owners has been there over 16 years planted by themselves). The tree has been shedding its leaves over the winter months, which we thought was normal, however now we think it may have died as the top seems wilted and the trunk seems to have some (not too much)what appears to be a fungus on it. The strange thing is that all the same palm trees in our area seems to have the same problem. Please can you give us some information as to what may be happening or what we should do, thanking you in anticipation. Kind regards Eileen Abela
    President:
  • 1,273 Answers
Hello Eileen, W/D here.
Palms will reabsorb some of their nutrients when fronds are shed, even over winter. If possible, you should let the ugly fronds go, and allow the trunk to take back what's stored in the frond stems. When they become brown, or less green, or droop, they can be pruned. This is usually found with the lower fronds. If upper fronds exhibit these symptoms, it is usually from the effects of winter, but the same rules apply, except that you can trim partial fronds to get rid of the brown leaves.
The acid test for a palm is, if there are shoots in the middle of the canopy protruding, to pull on them firmly, but not aggressively. If the shoots pull out easily, the palm is probably dead. Some winters are more brutal than others, and palms take the worst of them. We double-cover our palms, and place lights inside of the covering that we make, and the larger ones have made it over winter now for about 5 years. I have used incandescent Christmas lights wrapped around the trunk and hung in the canopies, then covered and it worked well too. One friend slaved his Christmas lights to his pool pump control panel, only to lose his palms. Seems that he was using LED lights, which put out no heat. Queen palms have died in droves this, and last year, as have unprotected Robellinis. Washingtonians and Pindos have fared better. If you live in a coastal zone, you still need to cover and keep your palms warm through the worst of winter. We have used fitted sheets on the smaller canopies to contain the fronds, then covered that with plastic tarps, weighted down on the sides to form a mini greenhouse, and it works pretty well, but it's inconvenient. With spring here, there will be a lot of new outdoor umbrellas purchased, and the old ones will be pitched. We already have picked one up from a neighbor, and will erect it over one of the palms, then cover it as described. The thinking here that it should be much easier (and quicker) to protect the palms via this method.
As for the fungus noted, try light applications of a fungicide, but check first with a local nurseryman to see what works best in your area.
Hope that this is of some help.
Best regards, (and please rate this solution), --W/D--
Posted on Apr 02, 2011
6FT. WHEN PLANTED NOW HUGE! SHORT NEEDLE IT WAS PLANTED WHEN I WAS 10 YEARS OLD IT WAS OUR CHRISTMAS TREE IN 1960.
Many pine tree species are fast growers.
Moving a large tree like that is very, very expensive because a crane and large truck are required. It can also be easily damaged. It is much easier to use an artificial one which is light and can be stored and re-used.
Write to the mayor in the cities you think might be interested and the Mayor's office will pass it to the appropriate member of staff to consider and reply. They are typically short of money and you will be very unlikely to get a positive reply.
Apr 08, 2016 | Vacuums
Why can I pull out brown fronds by my hands on my sago palm's trunk?
Usually once every year or two, Sago Palms bottom frond will die off in order to produce new ones that shoot out the top. Once they die you can pull them out with your hand because the fibers that attach them are also dead.
Jul 07, 2014 | Seeds of Faith Cycas revoluta - "Sago...
Pine tree diseases such as rust check. could i see.
Could be wind-burn. Some tree's don't like the wind as it dries out moisture in the needles. Move the plant or plant protective shrubs around it.
Jun 21, 2014 | Garden
Rubber tree plant
This can happen for a few reasons, all involving water in one form or another. A rubber tree that is underwatered or overwatered will curl its leaves. As will a rubber tree that is in too low of a humidity or in poor soil.
When watering water when the soil is dry to the touch about 1 inch down and then water with enough water to that water runs out the holes each time. This helps remove any build up of soluable salts. IF the tree has recently been moved and lost leaves, the tree should put out new leaves but they will not be in the quantity that they were when the plant was brought in. Fertilizer should not be used at this time of adjustment. Only after the plant gets settled into the new location and then about once a month or so.
Information About Rubber Trees
Feb 01, 2014 | Garden
Plant?
by the photo it looks like a japanese cherry tree
Apr 25, 2013 | Garden
My palm tree appears to have died following a recent cold spell. the leaves have turned brown and are falling off. is there anything i can do to save the tree?
Unfortunately,no not at this point.You will have to replace them.Next year use 1x2 stakes and build a frame to fit around and over the trees.Staple CLEAR pe tarp and you have an instant temporary green house.A roll of 100yards by 20 feet at Lowe`s is about 80usd,and can be reused.
May 13, 2011 | Garden
Ficus trees loosing leaves turnig yellow and falling off
How long have you had the tree?
Indoors or out?
If indoors, do you have any new plants in the house?
Have you moved the plant recently?
Your problem could be any one of:
  1. An infestation of tiny insects. Spray a solution of soap and water all over the plant, top and underside of leaves, until it is dripping. This will kill the insects.
  2. Overwatering. Hard to fix. Try transferring to a bigger pot and mixing in new dry soil. Or poke holes in the soil around the roots with the handle of a wooden spoon to let the air in.
  3. Underwatering. Put the plant in the bath, turn on the shower, set to tepid (i.e. not freezing cold and definitely not hot) and give it a good soaking. But take the pot out of the tray or dish and let it drain. It should not be in standing water. Don't water "little and often" - this is bad... give it a good soaking and then let it dry out.
  4. Chemical build up from tap water. If you see a salty-looking depsoit aorund the pot, or brown depsoits. do the same procedure as above.
Hope this helps.
Sep 01, 2009 | ArcMedia Home Gardening (SBX886) for Mac,...
Sport & Outdoor - Others Logo
115 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
