Question about Cell Phones
When i turn it off, my phone is charging even if its unplugged. and when i turn it on it shows connected to pc and i can no longer use my samsung champ.
SOURCE: Samsung SGH-G600 connection to pc studio3
Try this, I had a the same problem as you guys + found this on a web forum. Quite a frustrating problem to have, It fixes the phone, but after a while you have to do this over again. I am wishing I never bought this phone, even though the reviews were really great.
Unplug usb cable from phone
Type *#52828378# into phone
this comes up
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
select 3 serial test
this comes up
1 PPP UP
2 Serial download
3 Run TCK
Select 2 Serial download
Phone will reboot.
Once rebooted, connect usb cable and pc studio will now work.
Posted on Oct 06, 2008
  • 4 Answers
SOURCE: why my samsung champ shows connecting to pc
If it doing this while plugged into a wall charger it is fine. If this is all the time: 1) Try turning it off and back on again. 2) If #1 doesn't work, remove the battery and wait 15min and put it back in. 3) If neither work call your carrier, they might know more
Posted on Mar 05, 2011
SOURCE: I want to connect laptop for internet using with
you need to download samsung kies software.. and install it. then automatically the required drivers will also be installed.. then follow the instructions as below..
NOTE: following instructions are for tata docomo internet. names may vary depending on your mobile network.
you just connect with bluetooth or data cable and find out the modem then u goto control panel ->phone and modem option then dialing rules tab ->new -> country/religion fill India and area codeand then ok. and then goto same dialog box in modem tab n select modem click ->properties and then advance tab n fill in extra initialization commands: AT+CGDCONT=1,"IP","TATA.DOCOMO.INTERNET" and then ok.
goto control panel ->network connection ->create a new connection ->new connection wizard next ->choose connect to the internet ->next ->choose setup connection manually ->choose connect using to dial-up modem ->next ->isp name -tata ->next ->phone number- *99# ->next ->next ->finish
then you a dialing tata icon in the desktop and you r connect internet in your pc
Posted on May 19, 2011
  • 27 Answers
SOURCE: 1) My samsung champ GT-
Possibly your handset is wet...try to disassemble it and here's the manual you needed. Manual
Posted on May 31, 2011
  • 33 Answers
SOURCE: auto charging and pc connectivity
just change charging connector if not then change chrging ic 100% ok
Posted on Jun 06, 2011
Samsung gt e3213k charging problem.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 07, 2012 | Samsung Cell Phones
Samsung brightside will not turn on.
If the phone lights up when you plug in the charger it is probably the ribbon cable that flexes every time you open the keyboard. About 25 bucks from cellphonerepairshop.com. Be sure to flip up the little latches on the flex cable ends before attempting to plug or unplug the cable ends.
May 26, 2012 | Samsung Verizon Brightside Sch-u380 Black...
My samsung champ always appear connected to pc! and it always apear to be charging even if unplugged?what should i do?
My samsung champ always appear connected to pc! and it always apear to be charging even if unplugged?what should i do? thnx...
Mar 14, 2011 | Samsung Cell Phones
I just tried to connect the samsung DUOSBT5722 to pc with windows XP OS. Kies has been installed. The phone continuosly shows "connecting" even after 15 min. and not recognised in Kies programme....
I had this problem. Don't know why it is not detecting it. I just installed Kies on different pc with windows xp it worked since I had spare system at home. It seems there should be some conflicts
Nov 27, 2010 | Samsung B5722 Cell Phone
I have Samsung SGH-D780 . I just buy data cable for this model. Generally it is supposed to charge my mobile whenever I connect my mobile to PC or laptop through this data cord. But doesn't charge my...
HI, THERE IS NO NEED TO INSTALL ANY SOFTWARE FOR CHARGING YOUR PHONE VIA COMPUTER,.IT MAY BE THE THE PROBLEM OF YOUR BATTERY.CHECK IT.THANKS..
Nov 17, 2010 | Cell Phones
What happened: 1] My battery ran out. 2] I connected my phone to my Laptop so that it can charge 3] Usually the charging status shows on the phone. Not this time 4] I tried turning my phone on. But it does...
How long did you leave it connected to your PC?
Charging via a USB cable from a PC is slow - much slower than using a mains adapter. If the battery was fully discharged it might take ten minutes or so befor your phone has sufficient charge to turn on.
Alternatively try a mains charging adapter.
Apr 07, 2010 | Samsung SGH-L700 Cell Phone
this comes up
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
this comes up
1 PPP UP
2 Serial download
3 Run TCK
Phone will reboot.
Aug 06, 2008 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
107 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
