Question about Microwave Ovens
Unit will not turn on had it unplugged over night and still the unit will not reset
My plmv169dcd stopped working,looks like it has no power, but there is power at plug in. is there a reset button>
Not quite enough information. But, there is no reset button. Open unit check fuse. test all 3 door switches. They are the number one cause of problems and can take out the fuse or not. Other than that it will take more trouble shooting to find the problem
Dec 03, 2014 | Electrolux Frigidaire Professional Series...
We lost power several times last night during hurricane Irene. The power has been on for several hours now and I noticed the freezer LED display is reading "88" and the fridge display is...
If you don't want to roll the unit out, then turn the circuit breaker off in the panel. The quick disconnect does not reset the electronics for the compressor. Try that and see what happens.
Aug 28, 2011 | Microwave Ovens
Have power at the outlet, nothing to the unit. worked fine last night. no clock no child reset not nothing. is there a fuse somewhere or a safety device?
There is a main fuse in the microwave oven, it is located under the keypad near the high voltage capacitor "silver and rectangular in shape" make sure unit is unplugged and dis-charge the high voltage capacitor for safety. I find the reason in most cases, that the fuse will blow if there is a defective door switch.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Last night it started making a funny noise and it sparked
HAD SAME ISSUE 6 YEARS AGO.
ITS A MAJOR PART AND ITS NOT SAFE IN THAT STATE.
IT JUST SLIPS MY MIND AS TO WHAT IT IS CALLED.
UNPLUG IT.
CALL A REPAIR SHOP.
TELL THEM WHAT HAPPENED, TELL THEM TO QUOTE A PRICE.
KEEP IN MIND THAT A NEW MICROWAVE IS PRETTY CHEAP THESE DAYS.
GOOD LUCK.
Oct 02, 2009 | Sharp R-1480 Microwave Oven
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
Samsung Over range Microwave
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
Jan 04, 2008 | Samsung SMH7178STD Microwave Oven
Cooktop light - night light only
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Dec 16, 2007 | Sharp R-1480 Microwave Oven
Mind of its own!
there i s obviously a fault with the programming hold down your clear or reset button for about 20-30 seconds it should reset .or unplug at night.
Apr 22, 2007 | Bosch HMB402 Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
