Question about GE DPSR483EA Electric Dryer
Long dry time and squeaky drum - GE DPSR483EA Electric Dryer
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Apr 02, 2011
Dryer is making squeaky noise when in use
Can be a few things
worn or dry drum bearing at the rear.
worn drum slides at the bottom front.
slipping drive belt.
But most likely, the tension idler pulley need some lubrication. This is a spring mounted pulley that keeps tension on the drive belt.
Oct 13, 2016 | Dryers
How do i fix a squeky electrick dryer
Usually Squeaky means dried out Drum Belt or worn out wheels that support the drum.
Jun 06, 2015 | Dryers
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
When i turn on the dry it is making a loud Squeaky sound. the dry is still heating, just making loud squeaky sound
Hi an welcome to FixYa, I am Kelly.
This squeaky sound your hearing is usually the idler pulley, idler pulley shaft, but also can be the motor or the drum roller bearings. Usually if the drum roller bearings are bad the dryer will thump as it rotates.
The idler pulley and lever is and assembly that is item 8 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598568#d28598568
Since it is squealing at this time when you have the repairs done that you replace the belt that is item 21 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572
The motor is item 7 this link:
I recommend that if you do the repairs that you replace the idler pulley, the drum rollers, and the belt.
Drum rollers are item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572 (make sure to check the drum roller shafts that are item 19 of the same link.)
While repairs are being completed also inspect the drum front and rear seals. Thare are items 14 and 26 (Same part number) of the above link.
By doing all of the above you should be able to get many more years of service out of your dryer.
If you need to purchase a service manual for self repair it can be downloaded here for $9.95:
http://allrepairmanuals.com/maytag-dryer.htm?model_number=MDE308DAYW
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Maytag MDE308DAYW Electric Dryer
My dryer makes a squeaky sound during adrying
the front guides around the drum or the bearing at the back may be failing partially or bearings in the motor may have started to noise,there is also the chance that the belt idle pulleys have started to wear,more than lightly it is the belt idle pulleys that have dried up or the bushings have started to wear
Jun 30, 2010 | Kenmore 94702 Front Load Stacked Washer /...
My tumble dryer squeaks really loudly when its going and seems to be taking ages to dry - any idea?
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Oct 27, 2009 | Hotpoint Dryers
Maytag MDG3000AWW Hard starting
your motor bearings or idler tensioner bearings are going dry and need repl
Aug 03, 2009 | Dryers
Squeaky brake when cold
If your rear brakes are making the noise take off the rear drums and spray some brake clean in there on both shoes and the drum let all parts dry which wont take anywhere from 30 seconds to a minute or two depending on the brake clean also if you want you can have someone take a piece of emry cloth to your front rotors and scuff them up a bit with about 80 to 100 grit emry and spray them and the pads off with brake clean let it dry to you can emry the pads to this will get most if not all the glaze on pads and rotors.
Feb 19, 2009 | 1994 Hyundai Excel
Nextra7 condenser dryer making squeaky noises
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Apr 18, 2007 | LG WM-2277HW Front Load Washer
GE DPSR483EA Electric Dryer Logo
88 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
