Question about Malber P25 Front Load Washer
The wire coil that holds the rubber piece on to the door of my Malber p 25 came off. A malber disturber/repair man can to check out the problem. He said the drum was broken and not to use machine because it would flood. He also said for how much a new drum would cost I should just buy a new machine. Does this sound right to you? Thnk u for you time.
  • hschis9256 Apr 05, 2011
    yes, thank you
  • Malber Master
  • 19,396 Answers
Hi.
If the drum or if the
drum shell (outer tub) is broken the drum can go backward and damage the door seal, as it happened in your case. If the technician's diagnosis is correct, the drum replacement will be a major repair, and the part will be quite expensive. A drum costs about $200, the outer shell (if separate kit) is over $100. Along with the drum, seals, supports and drum bearing may need replacement.
If what is broken is the support at the back of the drum, the repair will also be expensive. The rear drum support costs about $100. To give you an example of parts price, here an example with an LG similar to your front loader. Malber parts are not listed online or in parts database catalogs.
Parts for Malber are not listed online. They are purchased calling Malber number, which is listed on manual. Malber website had been recently closed (Jan.2011), and I am not sure if the business is still in operations.
Here Malber USA contact:
Malber USA
61 Commercial Avenue
Garden City, NY 11530-6417
(516) 294-6660
Website: (not working, there is an advertising site in place):www.malberusa.com
Resuming:
If there is a major repair to be done on this appliance, I agree with the technician, the repair is not worth and it is better purchasing a different appliance.
Regards.
Ginko.
Posted on Apr 02, 2011
Spin cycle not working on Malber washing machine, it is on a used boat we just bought and it is in Fort Lauderdale but coming to NY soon, boat broker says he cant locate a person to fix the Malber- an
In New York, call Malber Distribution Corp at 516-323-5299.
They can schedule a technician to fix your machine. They've been fixing Malbers for about 25 years.
Tell them Mike, in Wash DC, says hi.
Mar 06, 2014 | Malber WD1000 Front Load Washer/Dryer
Malber WD2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won't release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don't pull too ******* the white door handle. If you can't open it with your little finger (seriously) it's not ready to open!
Nov 14, 2013 | Malber WD2000 Front Load Washer / Dryer
My malber wd2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won\'t release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don\'t pull too hard on the white door handle. If you can\'t open it with your little finger (seriously) it\'s not ready to open!
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 30, 2012 | Malber WD1000 Front Load Washer/Dryer
Malber TD700 sensor tumbles but no heat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 05, 2010 | Malber TD700 Electric Dryer
Need service for Malber 1000 heating element..
Hi. Mike here. I repair Malbers in the Washington D.C. area. The most likely problem is not the heating element, but the hi-temp (or "brown") thermostat. They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord). The same stores also sell tubular "crimp-on" wire-connectors (little blue tubes) to join the old and new wires. May God bless.
Mar 02, 2009 | Malber WD1000 Front Load Washer/Dryer
Rubber piece
If you mean in the bottom of the gasket between the drum and the door the hole is to allow water to drain from the gasket to prevent standing water which will smell .
Aug 08, 2008 | Malber P25 Front Load Washer
Front door will not lock
The door lock may need to be replaced. It is a simple fix requiring only a screw driver. Contact Malber at 1-800-600-8913 and ask for Neil.
Dec 19, 2007 | Malber WD1000 Front Load Washer/Dryer
Where do you gets parts and schematic?
check two places. repair clinic dot com and parts select dot com
Sep 06, 2007 | Malber WD1000 Front Load Washer/Dryer
Malber P25 Front Load Washer Logo
93 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
