Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Moving intermittently - Zodiac BARRACUDA G3 IN-GRND CLEANER
  • 640 Answers
Check for the following problems with these pool cleaners. Check diaphragm for blockage or damage. Adjust a worn diaphragm by loosening cassette swivel, gently pushing down on inner pipe, and retightening cassette swivel. You will probably need to replace the diaphragm if that doesn't work.
Posted on Apr 20, 2011
Throttle Pot Assembly for my CTM HS890 is faulty as everything else works but there is an intermittent fault eg going an not goin is there a second hand parts site in the UK as they are expensive.
Connect it to a ohms meter and slowly move it from closed to open, if the meter moves freely to and fro without a flicker its ok, if the meter flickers or goes to zero the unit is faulty. If you have to go secondhand do the meter test.
Feb 02, 2018 | Cars & Trucks
Kia soul rear window wont roll up 2012 kia soul
Try spaying the window tracks with lithium grease. The circuit breaker is tripping trying to move tight window
May 22, 2017 | Kia Cars & Trucks
Intermittent motor head
Hi there, it's Jack at Dyson.
If your DC35's motorised cleaner head seems to work intermittently or cuts out when moved, this suggests that there could be a loose connection somewhere. We're keen to help you check for this, and our experts can talk you through some simple diagnostic checks to pinpoint the cause of the issue. If a replacement part is needed, we can also confirm whether or not your DC35 is still covered under its Dyson warranty.
When you have your DC35 fully charged and easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 19, 2015 | Dyson Vacuums
2004 Mercury Mountaineer cruise control only works intermittently.Could a weak ground be the problem?If so how do I find?
I had this problem it was the switch on the break pedal it would move just enough so the break light did not come on but the cruise would not work
Jan 13, 2013 | 2004 Mercury Mountaineer
My chevrolet aveo won't intermittently move from 2nd to 3rd or 4th gear, and have to reduce speed and move back down to 2nd and try again ....notice it more if trying to move up the gears quickly
This transmission is electronically shifted via solenoids controlled by a computer, so you need to have that tested for fault codes that may be in memory.
Jun 07, 2012 | 2010 Chevrolet Aveo
The windshield wipers on my 2001 c240 only work when I am moving but quit working if my car is at a stop...I hope it is an inexpensive fix. Any suggestions would be greatly appreciated. Thanks
IT's your intermittent speed - they only work when moving when set on intermittent. If you go to normal or hi and it stops, then you have bad switch or relay. Sorry to say there's nothing on a BENZ that's inexpensive to repair - I used to work for them.
Mar 09, 2011 | 2001 Mercedes-Benz C-Class
RH rear view mirror responds intermittently when selected and attempting to adjust. On lexus RX330.
Check for anything that could be jamming the mirror, can you move the mirror in the housing manually.
Can you use the controls to move the mirrors to the rhs, up dn and lhs extremes. This may pop a gear that may be out of position.
Last if it is an intermittant elect connection, pop off the switch from the dash to check the connector on the back.
Jul 07, 2010 | 2004 Lexus RX 330
Intermittently screen move to one side with distrited picture
Might be the convergence chips. Do you have any problem moving the convergence under the menu setting? Convergence chips are reasonably priced. If you know a friend or someone who can solder better than average, I would go this route. My tv wasn't that bad; I wasn't able to set 2 of the 3 colors during convergence setup. Changing the 2 convergence chips did the trick!
May 24, 2009 | Philips 43PP9202 43" Rear Projection...
Wipers do not work in intermittent position. They do work in low and high speeds but do not automatically return to the park position. They stop wherever you turn the switch off.
i belive that your wiper switch has gone out on the intermittent side. this is a very common problem.
I hope this helps you
Thanks
Please leave rating
Apr 21, 2009 | 2000 Isuzu Amigo
I have a peugeot 406, V.reg 1999 model. all the dials are fluctuating up and down and the fuel gage reads empty even when full?? Any idea's??
I don't know this car, but it could be that an intermittent short in the fuel gage doesn't give enough time for the fuel needle to move, but does effect all the other dials intermittently. Or maybe the instrument panel has a ground wire that is intermittent. Good luck.
Jul 25, 2008 | Peugeot 405 Cars & Trucks
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
131 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
