Hi
If the washer is
not draining then it is due to a clogged drain pump or a drain filter or a
kinked drain hose. To resolve the issue you'll need to clean the drain hose,
inspect if the drain hose is plugged. If the hose is fine, then remove the
front kick panel and access the drain pump and filter, if you are unable to
find the pump and filter remove the back panel as well and trace the drain hose
to the bottom of the tub. There is a drain filter connected with the drain
pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so.
The drain filter is a small white filter connected to drain pump with a hose.
If it still doesn't work then you'll need to check the connections of the drain
pump, check the electrical connections with a multimeter. If it still doesn't
work then you would need to replace the drain pump.
Hope this helps... Please
post back if you need more information.
Daniel
