Question about Kenmore 22422 Top Load Washer
Kenmore 70 series - not draining
My washing machine is not draining. I checked the hose and it is not blocked, I believe it is either the switch or the pump. Last week while on the spin cycle I opened the washer and it did not stop spinning like it normally does. It is fine during the wash cycle, but it will just click and stop when it gets to the drain portion. It is only 8 years old as well, so I hate to buy a new one if this can be fixed at a reasonable price. Any advice?
  • sunnysusan50 Apr 08, 2009
    water doesn't drain. I beleive it is the lid switch but cant figure out how to get to switch to replace it. I have Kenmore series 70 model 110.22712100. thanks any help would be appreciated
    Novelist:
    Champion:
  • 261 Answers
On your console there is two side panels that pop off from the top and two screws to remove and then swing the console back. You will notice a molex plug going into the washer on the right hane side. Unplug the machine and the top portion of that plug. Get a meter for continuity and if it beeps with a open lid or not when closed I would replace the switch.
Posted on Oct 21, 2008
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
How do you replace the lid switch on a Kenmore 70 series washing machine
Hi.
Check for drain blockage at the filter. Check setting of drain hose at the back. If there is no drain problem check pressure switch, central control unit and pump motor.
Here a tip talking about drain and spin problems: http://www.fixya.com/support/r7775926-no_spin_tip_all_washers
Nov 13, 2011 | Kenmore Washing Machines
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
My kenmore series 70 washing machine is leaking water from under the front of the machine. i've checked the drain hose and it seems to be OK. what else should i check
http://appliancejunk.com/forums/index.php?topic=5191.0
Use the link above to access the drain pump. It is the cause of your leak.
Nov 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 will not fill
Ive only run across this a couple of times in my years of appliance repair. This sounds like you do not have an air gap on the drain hose. Where the hose hangs into the wall drain pipe make sure you do not have that sealed air tight with duct tape around it or something. It needs to have a gap all the way around the hose and just hang freely. If it is sealed off then it creates a siphon effect and sucks the water right out of the washer tub into the drain.. Hope this helps.. Thanks
Feb 18, 2009 | Kenmore 22422 Top Load Washer
Water won't drain
This is usually caused by the lid safety switch. When the switch malfunctions, The washer believes the lid is open and the washer will not spin or empty. The switch is intended to prevent injury during the spin cycle. The timer could be bad but it is usually the switch..
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Same problem
ck lid switch blocked pump would not prevent spin unless it was locked up then probably wouldn't agitate either
Jul 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
481 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
