Question about Electronics - Others
I need the proper power inverter to use from my car. The inverter has 12volt clamps & is 400watts with 3.5 amps. Is this the proper device to operate a stanley 4 gal. Stainless steel 300 wat a/c wet or dry vac. Can I safely & with confidance use this in my new business?
  • 9 Answers
SOURCE: NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Posted on Feb 03, 2010
javeedcare
  • 316 Answers
SOURCE: I have an old shop
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Posted on Jul 04, 2011
SOURCE: I have a 10 Gal
Here are links where the hose can be purchased.
The parts for this Model seems to have been discontinued, but there are some that still sell the part, check the link provided to get more details of the part needed, thanks.
Link1 Link2 Link3
I hope the link help, I saw the hope on Link3 and Link2, on Link1 is where the original part can be bought but has been discontinued in the market, I put the link just for details on what the original part would look like to be able to buy one that the same from the other 2 links.
Have a nice day.
Posted on Sep 07, 2011
  • 1456 Answers
SOURCE: I have a new stainless
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
motor1258
  • 6674 Answers
SOURCE: I just bought Stanley 4.6
Try this link to contact for PDF manual download of you r product.
http://www.altonindustries.com/stanley/home.asp
Posted on Sep 21, 2011
Why do the fuses blow out every time I plug it in
watts divided by volts equal amps so 400watts devided by 12 volts equal 33 plus amps if wires and fuses wont handle 35 amps they will blow to keep from burning up the wiring of your vehicle
May 14, 2015 | PEAK 400 Watt Tailgate Inverter Max -...
Fault Light/ inverter failure
the current from the 12volt supply is not sufficient try a fully charged car battery instead, your inverter needs 30 amps and above of current from 12 volt power supply
Jul 20, 2013 | Televison & Video
What is the amp size of the external fuse of a whistler 400 watt power inverter
The lighter socket power cord has a 15 amp fuse. The cable with the battery clamps do not have fuse protection.
Aug 27, 2012 | Whistler 400-Watt Power Inverter - Silver
Need to know what size fuse how many amps and volts for this device.
Rule of thumb for 12vdc to 120vac inverters is 1 amp of fuse for every 10 watts of power. So, this one would use a 7 amp fuse.
Jul 06, 2011 | Inverter Vector Power - 70 Watt, Model...
My MTX continues to draw power even when the key is not in the ignition. What can I do?
It sounds like you have constant 12volts applied to your remote turn on lead. The amplifier will have 3 connections for power:
1. 12volt constant
2. chassis ground
3. 12volt switched power - this wire should come directly from your head unit. It only sends 12 volts when the radio is on allowing to amp to power up only when the radio is on.
Dec 22, 2010 | MTX JackHammer JH600 Car Audio Amplifier
Is the brutus amp blue led light suppose to stay on when the car is off?
No. The LED should be off when the radio is off (amp turns off as well)
1. 12volt constant
2. chassis ground
Dec 22, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Cannot get pyle driver 413 bridgable mosfet1000 watt amp to work with 800 watt subwoofer . followed instructions all the lights are lit but no sound need help
just wondering how you connected the amp . you should do the following steps
1 battery cable with right size fuse at battery
2 remote wire from radio
3 rca cable from audio out from radio
4 ground the amp to a good clean piece of metal
then make connection on the amp
1 battery or power cable to the 12volt connector on the amp
2 remote wire to b+ or rem on the amp
3 rca cabel should be pluged in the channels are using cause you tell me that the amp is 4 channel
from the model numbers
4 clean and scrape off paint on the metal surface you are going to install the ground cable from the amp . make sure your ground is no more than 12 inch max. and is the same gauge as the power cable
5 . run your speaker wires to the amp and make sure your ohm load for the subwoofer is 2 ohms or 4 ohms to make the amp work proper .
if need help on anything email me @ caraduioquestion@gmail.com
Oct 29, 2010 | Pyle Car Audio & Video
Have hooked up al conections properly acording to diagams but amp will not pwer up. tested wire conections and i am getting juice to the amp but still no responce fuse are good amp is brand new out the box...
If this is new out of box make sure you have 12volts to the amp turn on wire. You should have constant 12volt + to the battery terminal 12volt- to the ground and 12volt + from the head unit (radio) to the amp The turn on wire on most car stereos is a thin blue wire. run this wire to the amp's terminal and when you turn on the radio the amp should turn on.
Sep 29, 2010 | Pioneer GM-D7400M Car Audio Amplifier
What kind of amp do i need for 2 kicker ds6930 140 watts peak and 2 ks6930 6x9 watts peak 150 and 3 Kicker KS350 3-1/2 40 watts each peak
600 Watt to 1000 Watt 4 CHANNEL AMP for the four 6X9's and a less powerfull 4 Channel amp thats at least 200Watts to 400Watts peak for the 3 3-1/2 kicker speakers. Because if you try to connect the 3 3-1/2 speakers to only 1 4 channel amp that the 6X9 speakers are on you risk of overheating the amp and blowing the speakers too!!!
Apr 05, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
Installing a car stereo in my house
You would do best with a 12volt inverter. It will bring the house voltage down to the necessary 12 volts for your car stereo. Best of Luck.
Oct 02, 2007 | Infinity Reference 7541a Car Audio...
Electronics - Others Logo
137 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
