Question about Interface Ford Focus 2010 10 Retain Nav Radio Removal Interface
How do use the USB outlet with the memory stick after you insert the stick with MP3 music
My usb stick to play music in car
Check whether the music is of mp3 format..and the music system is capable of playing a USB.. Thank u
Jan 26, 2015 | Computers & Internet
Can you play a mp3 on this radio and if so how
According to the specs it can play MP2 and MP2 music files,
You can check the specs from this WEB site.
http://shop.panasonic.com/shop/model/SC-HC27?t=specs
You need to copy the MP3 music files to an USB memory stick and connect it to the Panasonic then select the USB memory stick music file to play.
May 12, 2013 | Panasonic Sc-Hc27 - Micro System - Radio /...
How do i put music from my p c to my psp
To play mp3 on your PSP, you'll need
  • A big enough memory stick duo. The 32 Mb that comes with your psp will only fit a few songs. To really make it practical, i recommend that you try and find 1G memory stick. If you look hard enough, you'll be able to find one for about 0
  • You'll also need a Mini-USB (USB A to USB Mini-B) cable or a memory stick card reader to access your memory stick from your pc.
1. Connect to your memory stick
If you are using memory card reader I assume you already know how to do this. If you are using USB cable, simply connect the cable to your PSP and Windows will detect it as a new drive.
2. Copy your music into the folder named "MUSIC" inside the "PSP" folder.
In the memory stick, there should already be a folder called "PSP", if there aren't any, you haven't been playing any games! Inside the PSP folder, find a folder named "MUSIC". If it is not there, don't worry, simply create a new one.
Now, simply copy your mp3 songs into this "Music" folder and you're done. You can also create folders inside the "MUSIC" folder and put your songs there.
Mp3 Playback Tips
  • To save battery, you can turn of the screen by holding the brightness toggle button for more than 1 second.
  • Press the triangle button to view other options such as repeat mode and the built-in help.
Jun 19, 2011 | Sony PlayStation Portable (PSP) Console
Is alpine going to upgrade the usb formay from fat32 to ntsf for playing memory sticks in unit or how do you format music to fat32 on a windows xp ntsf format without wiping out hard drive
The Alpine CDE-103BT requires only USB media that is FAT12/16/32. You can format your USB medium on your PC to FAT32 then copy your media (music) to the the USB drive.
Insert your USB Drive to the PC On your PC navigate to Start ->MY Computer Then locate your the drive that is your USB Drive. At this time you will want to save any of your data before continuing. All Data on the USB drive will be lost. Next ensure that you have selected the correct drive. Right Click on the drive on go to format... Under File System select FAT32. I would suggest leaving Quick Format unchecked. So you ensure that will information is removed. Then Click start. Next copy your media (music) back to the USB Drive. Insert in to the CDE-103BT Stereo.
Notes: MP3/WMA/AAC files are prepared, then stored to a USB memory. This unit can recognize at least 100 folders (including root folder) and 100 files per folder stored in USB memory. Do not make a file's playback time more than 1 hour.
Nov 07, 2010 | Alpine CDE103BT CD Reciever iPod and USB...
I dont know how to put music on my psp
Copy the MP3 files (must be MP3, or WMA Format) into your MUSIC folder in your Memory Stick. You must have a memory stick inserted to download files.
Nov 07, 2009 | Sony PlayStation Portable (PSP) Slim...
Music player error
It works just as long as you first format your memory stick when you first insert it into your phone then drop and drag your MP3 formatted songs onto it via USB cable or through your MicroSD reader on your computer, just make sure it's in the correct folder which is the "my music" folder on the memory stick, then go to your media folder and play it from there. Aloha!
May 30, 2009 | LG enV VX9900 Cellular Phone
Music to my easyram 2gb stick 4rom internet.
There are several ways to transfer music into your memory card. Please read the options below:
1. Main thing to do, download music to your computer using a program (i.e. Lime Wire)
2. Save the downloaded music to your computer where you can easily find it.
3. You need a USB card reader where you can insert your memory card.
4. Insert the USB card reader while the memory card is inside of it.
5. Make sure that the computer will recognize your memory card and verify the drive letter that will be assigned to it. (i.e. D:)
6. Locate the music and then right-click on it and then select Send To.
7. Select the drive letter of your memory card (D:) and the music will be transferred to it.
*Another thing*
1. Open the driver letter (D:) assigned to your memory card by double-clicking it.
2. Highlight all the music that you would like to transfer.
3. Place the mouse pointer to the selected music and hold down the left-click button of the mouse and then drag it over to the memory card.
Mar 26, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I need to play music from my Kingston Memory Stick to my Radio
Try reformating the mp3 files to wav. or is there a option on the radio for usb?
Mar 03, 2009 | Pyramid 906 Car Equalizer
Razr v3xx mp3 player
all right so you purchased the memory sticks and the usb cord so your good to go first thing is the small memory stick needs to go in the phone so to do this remove the back cover of the razor and there should be underneath the battery left to the sim card a slot insert the memory stick in the slot(follow the arrows) attach the cover. next take the larger of the memory stick or the adapter and if computer compatible insert into computer (optional) next take the usb adapter cord insert the large usb side into the computer the other side in to the charge port on the razor. a window should come right up asking ou what to do click view folders now when next window comes up select the folder and drag music into appropriate folder. any further questions or more indepth instructions nmartell@comcast.net only for actual help no **** please
Apr 29, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Usb cable
Just like sorta of add-on to szwaan's answer:
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
Dec 21, 2007 | Sony PlayStation Portable (PSP) Console
Interface Ford Focus 2010 10 Retain Nav Radio Removal Interface Logo
Top Interface Car Audio & Video Experts
xxxxxx xxx
Ted Maxwell
Are you an Interface Car Audio and Video Expert? Answer questions, earn points and help others
