Question about Garden
With the sanli bettle lawn mower looking from the bottom up is the blade removed unti clock wise.?
  • 2,239 Answers
The blade retaining bolt is a normal right hand thread ( anti clockwise )
Posted on Apr 02, 2011
Cant remember how to put blades back on
your motor runs clock wise , hold the blade under it
and look to make sure the cutting edge of the blade
will be turning clock wise also .
Oct 07, 2012 | Garden
The oil drain plug (at bottom of elbow) is stuck on Craftsman LT4000 12.5 hp riding mower - I can't move it either way. Before I force it, I would like to make sure which way it should go to remove...
Hi, because you are looking down on it, it needs to turn clockwise. But if you were looking at it from underneath it would turn counter-clockwise. I hope that makes sense. Regards Phil
Aug 28, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you change the blade on a craftsman lawn tractor model 917.28726? I have the tractor on ramps, but can't seem to get the bolt off!
Disconnect the spark plug wire from the engine to prevent accidental starting. Use a wrench or socket to remove the bolt, turn in a counter clock wise rotation for removal. You'll need to hold the blade still while attempting to remove the bolt. Use a breaker bar for more leverage if needed,sometimes these bolts are difficult.
Sep 01, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Turn the right or left to remove the nut
all most every blade mount bolt turns out in a counter clock wise rotation facing the bolt head
Jul 31, 2010 | Honda Arnold 21" Mower Blade 490 100 ...
I have a Murray 40 inch riding lawn mower and I had to replace the blades - which I did but when I went to mow the lawn it dug up my lawn so I thought I put the blades in wrong so I reversed the blades and...
It sounds like your mowing deck is too close to the ground. Can you adjust the blade height with a lever? I have a Craftsman riding mower, my deck height is adjusted manually with the use of a locking level shifter, be sure yours is set to the proper minimum height and this will eliminate driving the blades into the turf.
Sep 21, 2009 | Garden
I have the Toro edger/trimmer combo - which way does the edger blade bolt turn - I tried counter-clock-wise it won't budge. Also how to the LOCK the blade from turning??
on blad removal the nut goes opposite to tighten, lefty tighty, righty loosen. Put a metal wrench or rod in between the blade and the guard to keep the blade from moving.
Jul 14, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mower carburetor
It is a tecumseh , remove screws from intake pipe to block
mark holes for linkage don't stretch springs.
Remove bottom bowl nut it is reg thread so turn counter clock wise . parts needed 631021b bowl gasket and needle and seat,
36786 intake gasket,
632547 2 o rings,
36905 air filter .
Use a can of carb cleaner auto zone spray all holes even the one
on the bowl nut , take out center plastic main nozzle out put on the new o rings put back in , some time the nozzle will brake part 3 640019 .
Remove seat can use comp air or make tool out of paper clip don't
scratch the side when pulling out
Good luck
Feb 02, 2009 | Oregon Scientific Oregon Fusion Blade For...
Changing oil
UNDER MOWER WHERE THE BLADE IS THERE IS A PLUG WITH A SQUARE HOLE THAT A 3/8 RACHET WILL FIT IN TURN IT COUNTER CLOCK WISE. THAT WILL DRAIN THE OIL.
Sep 16, 2008 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
