Question about Garden
Will not start because it has no spark.we have the coils in australia, the generator is in the solomon islands,how can we get the coils checked or what else could be the problem. thank you Peter Aldridge
  • 55 Answers
SOURCE: 1991 pontiac sunbird ignition problems.
I have a 1994 pontiac that was doing the same thing. My problem was the torque converter, just unplugged it and hasnt stalled since
Posted on Nov 29, 2008
wayneman01
  • 301 Answers
SOURCE: no spark on spark plug
To check the ignition coil, unplug the wires going to it and check the resistance with an ohm meter. There are two parts of it to check, the primary and secondary circuits. The primary circuit is the low voltage side where the black and green wires from the harness attach. The resistance through this part of the coil should be between 0.16 and 0.19 ohms. Check the secondary side by measuring the resistance between the spark plug lead and the primary side where the green wire was attached. The resistance there should be between 3.69 and 4.51 ohms.
The resistance through the pulse generator, as measured between the two wires that come from it, should be between 468 and 572 ohms.
Generally, the various components of the ignition system are very trouble free. If you're not getting spark to the spark plug, be sure to check all of the bike's wire harness and connectors for corrosion, melted connectors, broken wires, etc.
Posted on Nov 22, 2009
SOURCE: hi, i have a clarke generator g900 ,no spark
this gen has a oil level sensor that will short the "primary" of the ignition coil as well as a spark enhancer that is called a CDI unit but the drawing does not show a Capacitor in or near it?
I hope this helps
Where did you get your replacement coil Colin?
Peter
Posted on Feb 14, 2010
  • 691 Answers
SOURCE: I have a W reg 2000 kawasaki GPZ 500 s, with an
do you have a circuit diagram. have you traced the system through. Sounds to me like it is an issue before all that, either with the junction box or IC igniter. The stop switch could also be an issue as could the ignition switch. Keep posting if you want me to have a closer look at my wiring diagram
Posted on May 02, 2010
  • 40 Answers
SOURCE: Whats the ZIP CODE for
ZIP codes are not used in that country
Posted on Mar 09, 2011
Huskey 3650 generator will not start. Had it for at least 4 years and have never started it. no fire to spark plug
So check components responsible for spark such as the plug itself, and the ignition coil and the gap for spark generation. Probably a bad coil.
Sep 04, 2017 | Electrical Supplies
Portable generator won't spark.
replace the low oil level sensor pack
it controls spark
Jul 20, 2016 | Generac Electrical Supplies
Hi! my name is Kea, I'm from Solomon islands I had a phone Sony xperia but sim locked from Australia... Please can anyone help me with the codes....
Contact the supplier of the sim card. They should be able to help you providing that the phone has not been reported as stolen.
Feb 13, 2016 | Sony Cell Phones
EU3000is inverter generator. Why won't it start?
Check the switch on /off is not faulty try taking the wire off the switch that goes to the motor mine had that problem (lot of dodgy switches fitted to them ,make sure the choke is closing on fully.check spark plug not fouled up with carbon.
Oct 03, 2015 | Electrical Supplies
Country with 0067 country vode
There is no country code +67 or 0067, but several three-digit country codes begin with +67. You need another digit. Country codes +670 through +679 are for various countries
  • +670 = Timor-Leste (East Timor)
  • +672 = Australian External Territories (Norfolk Island, Antarctic bases)
  • +673 = Brunei
  • +674 = Nauru
  • +675 = Papua New Guinea
  • +676 = Tonga
  • +677 = Solomon Islands
  • +678 = Vanuatu
  • +679 = Fiji
Mar 24, 2015 | Cell Phones
Why do I have no spark at the coil
A few things can cause lack of spark at the ignition coil. This assumes pointless ignition system.
  • The stop terminal is intentional grounded IE stop switch on.
  • The stop circuit is shorted to ground.
Remove the plug wire from the plug so engine can not start. Remove the stop wire from the coil and try starting the engine while testing spark. If spark is now present then check the stop circuit.
  • The coil pack itself is bad.
  • Flywheel magnets are demagnetized.
These can check by seeing they attract heavy metal object strongly.
Dec 24, 2014 | Coleman Powermate Powermate 5000W...
Mcculloch generator fg7000ma will not start. changed spark plug still nothing
do you have spark if not first check off on switch if good check coil and flywheel for rust if no rust coil is bad
Sep 12, 2012 | McCulloch 13HP 338 Cc Portable Generator #...
Unlocking a LG tu 5005 on telstra network for NZ vodafone network???
Want to unlock my lg ph used in australia,but to used in solomon islands.IME I:356163-01-000277-8
Oct 23, 2008 | LG CU500 Cellular Phone
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
