Question about Refrigerators
My freezer isnt getting that cold\,the ice dispenser is,nt working and the display panel is only half lit up,its a daewoo u20bc
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
My GE side by sides front panel is not working and won't dispense water or ice . The fridge is cold and freezer is cold . But no water or ice or buttons are not lit up,or working
That has to be an issue with the controller because the likelihood of both systems going bad at same time is remote.
Neither fill valve is being activated with the voltage to open it. Or check the water source to make sure the water is there on demand. Need parts?
Search Over 2 1 Million Appliance Parts
Sep 12, 2017 | GE Refrigerators
Daewoo frsu20dci fridge freezer, hiya, hope you can help. Our fridge freezer is making ice and dispensing ice but no water is coming out of the water dispenser when pressed. Help!!!
Check your water filter. They are known for clogging up. If that doesn't work...check your water inlet valve.. if that doesn't work check to see if you have a pinch in your waterline.
Jun 25, 2015 | Daewoo Refrigerators
It won't dispense water and my control panel is lit up and flashing from item to item. Do I need to reset it? My husband pushed a lot of buttons to try to stop the ice maker and ever since then, it w
First, try unplugging the refrigerator for 5 minutes and then plug it back in. If the problem persists, you will need to replace the dispenser control module.
Apr 20, 2014 | Fisher and Paykel Active Smart E522B...
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
The display panel shows OF and now it's not getting cold in either the freezer or frig.
he letters "OF" on the display of your RS267TDRS indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and a numeric reading returns to the display, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
The freezer compartment of my daewoo FRN-U20DA is not cold enough and the ice is melting. The fan does not come on and there is no fault indicated on the display panel.
when the fan is not working. you cannot expect an ice cause the fan is to drive the cold to become an ice and to maintain the coldness.
Jun 23, 2010 | Freezers
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser not working, temperature display off then on
If you pull out the collecor of ice can you then hear and see rotater arm rotating in the back of freezer. If not you need to remove panel and check for voltage at notor and inspect motor.
If you have 120vac and no motion you'll need to replace motor. We have them same day shipping 704-819-6657
Mar 14, 2009 | GE Profile¿ Arctica® Energy...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
