You can change the region code for your drive a maximum of four times.
To do this Right Click on "Computer" ("My Computer" if using XP), select "Properties" from the drop-down menu, then select "Device Manager (or "Hardware Manager") and click the "+" next to "CD/DVD Drives" and then right click on the description of the drive that you want to change the region code on, select "Properties" and then click on the tab labeled "DVD Region." From the list, select the country associated with the DVDs you want to play or just manually enter "Region 1" (without quotes) in the empty field labeled "New Region." Click "OK" and you're done.
