I replaced the transformer and the thermostat and the gas valve still doesn't open.
  • Mike Butler
    Mike Butler Apr 02, 2011
    Lets start by getting a make and model number off furnace to better determine your problem.
  • 1,420 Answers
Not knowing what make or model of equipment, I can only offer some basics. We are going to have to start the troubleshooting at the thermostat. Take the two wires at the thermostat and jump them together, If nothing; take off the thermostat wires at the transformer and jump the terminals R and W together. If nothing, you will need a test light or multimeter to see if you have voltage out of the transformer. You can test if you have a bad gas valve by applying 24 volts to the gas valve directly. Make sure you have a pilot going so it will burn off the gas if the valve opens. If the gas valve opens and you get ignition, check the wiring for any bad wires or wires on wrong terminals. If there is a pressure switch, jump that out once the inducer motor starts running (if you have one). Re-post with make and model and we can narrow down some other diagnostics for you. I am going to assume you have no blockage in the gas line or are out of gas. OK?
Posted on Apr 02, 2011
Changed thermocouple and thermostat on wall heater but heater will not turn on.
Thermocouple senses the pilot light, the gas valve is controlled by the thermostat and that is powered by a transformer. Check for voltage from the power supply transformer to the thermostat. Check the gas valve for continuity.
Jan 19, 2017 | Heating & Cooling
How do i fix a forced air gas furnace?
Are you sure your thermostat is working. I would try to manually start it by bypassing the thermostat. Possibly bad valve then. That is unless it is opening and the jets are clogged. How old is the unit? Is it an electronic igniter or pilot light. I know you said you changed the mother board but start with step one again. Do I have gas to the unit? I know it sounds crazy but most of the time I found something so obvious I overlooked it. If everything is good I'd look at that thermostat though.
Jan 01, 2015 | Carrier Heating & Cooling
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Thermostat doesn't activate unit
Put a volt meter on the red wire and the C terminal. You should get 24 volts AC. If not then the control transformer is shot
Jan 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Drh55cg no heat appears to be no voltage at a small transformer secondary connects to gas valve there seems to be many safe guards
Since you have confirmed that the step down transformer is open, it is imporrtant to disconnect the secondary lead to confirm . If so identify the volatage to the valve and use a simialr voltage to be connected to it. If the fault clears then you can change the failed transformer.
However it is important to check the voltage to the other input areas so that the valve is opened so as to adjust the heat.
Use a multimeter to check, use a variable power supply to be bridged across the faulty output power.
Jun 13, 2011 | Kitchen Ranges
Pilot light on thermostat click main burner doesn;t come on
Don't know if the pilot has been cleaned or the thermopile has been changed. The pilot being lit can be good to keep valve open but not strong if enough to open main burner. If after checking all the above, make sure you have gas flow from the valve, if so replace thermostat.
Apr 01, 2011 | Vulcan EF3 Deep Fryer
The water heater red light keeps flashing rapidly on my Powervent 2 model 41VRP40N. It is not producing hot water and when I read the manual it says it needs more heat. What does this mean. How do I fix...
There are many things to check. The single most important test is for 24V at the gas valve after the ignitor is supposed tp be on. 19 V or less and there is either a bad ground or the ingition control board has failed. (Wire ground problems are a high probablilty)
Here is what the book says:
PROBLEM #1 - HOT SURFACE IGNITOR DOES NOT GLOW RED
(Remember to wait for purge time, 17/34 seconds, on models so equipped).
Possible causes
A. No main power
B. Faulty transformer
C. Faulty thermostat
D. Faulty limit switch
E. Faulty blower interlock switch
F. Faulty hot surface ignitor
G. Faulty ignition control
Solution
Step #1
Perform normal system checks of main power, transformer, thermostat, limit
switch, blower interlock switch, and replace faulty component.
Step #2
With power on and thermostat set at its highest position, check voltage
between "TH" and "TR" on HS780 ignition control. If 24 volts is not present
check output at transformer. If no, replace transformer. If transformer
checks out OK look at other controls in the 24 volt circuit I.E.: thermostat,
limit switch, blower interlock switch. Check for 120 volts between "neut"
(L2) and "120" (L1). Check for 120 volts at the ignitor across "IGN" and
"IGN" terminals on the HS780 ignition module. If 120 volts is present,
replace ignitor. If no, replace the 780 series module
PROBLEM #2 - IGNITOR GLOWS RED BUT MAIN BURNER
WOULDN'T LIGHT
Possible causes
A. Improper ignitor alignment
B. Faulty ignition control
C. Faulty gas valve
D. High inlet gas pressure
E. Polarity reversed
F. No earth ground
Solution
Step #1
Check for availability of gas at gas valve. Make sure the manual valve
upstream of the gas valve and the gas valve are in the full on position. Also
make sure gas is being supplied to the system at the proper pressure, too
high will lock-up the valve.
Step #2
Check proper polarity of "NEUT" and "120" on the ignition control by reversing
the wires, if reversed gas valve will not open. If this does not solve the
problem, replace wires as they were.
Step #3
Check for proper ignitor position.
Step #4
Check for a good earth ground by using a meter connected between L1
and furnace chassis. Should read 120 volts, if no, check and/or repair ignition
ground wire or ignition control mounting screws.
CAUTION POLARITY MUST BE OBSERVED
Step #5
Check for 24 volts at the gas valve terminals; "1" and "2" on a 7200 series,
"M" and "C" on a 7100 series, "TH" and "TR" on a 7000 series. If yes,
check wire integrity or change the gas valve. If no, change the 780 series
ignition module.
That is pretty much all of the troubleshooting required.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I replaced the thermostat because it wouldn't turn on, it still doesn't turn on. What else can I check?
Jump the two thermostat wires together at the thermostat, if it fires up; it is a bad thermostat. Jump the terminals where the thermostat connects to at the gas valve, if the unit fires it is a bad thermostat wire or connection. If the unit does not fire, check for 24 volts AC out of the transformer. If yes, bad gas valve, if no bad transformer or no power to transformer.
Dec 27, 2009 | Cozy (W352E) Heater
Installed dayton nat gas hanging furnace in garage and have 2 wires dont know where they go one came from the back side of the transformer it was twisted with the other wire
Hopefully there is a wiring diagram glued to one of the panels to verify but on the transformer you will have 2, 110 volt wires. One is the power coming in (usually black wire) and the other is a common (white wire) and will be connected to other common leads. On the low voltage side of the transformer one wire will go to the thermostat then from the thermostat to the gas valve. The other side will connect to the gas valve. When the thermostat calls for heat it completes the circuit from transformer to gas valve back to transformer.
Dec 11, 2009 | Dayton Gas Furnace Heater
Home atlas 98kb size. the thermastat does not turn polot fire on or off. repalced thermostat no change. pilot light is on. 24 voldt transformer is working . bypass straight to electirc valve and gas turned...
Did you bypass with the 24v.right to the gas valve and it opened? Sounds like that's what you are saying. This is a good way to test the valve but can be dangerous. Well, we do it all the time.If the pilot is on and the transformer is good, even though you replaced the stat, that is what controls you're gas valve to open on a call for heat? Double check the stat wiring, and make sure that you have 24volts from the stat to the valve when stat is on. You may have a bad spot in one of the wires.Check all of your control wiring,24 volts. You will find the problem in your wiring. Let me know. Good Luck,
Shastalaker7
Nov 07, 2009 | Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
