RIGHT DOOR OPEN SYMBOL IS FLUSHING WITH CONTROL CARD SYMBOL IN CANON NP 7161
Hi! I am facing this problem for along now my copier canon np 7161 it has two error symbol (1) control card symbol and (2) right door open
i tried to rplace all ckt bodies and also the door sensor but idid not solve the problem.
pls help me
(trouble shooter in big trouble - from Zanzibar,Tanzania)
  • 162 Answers
Verify the state of fuses in power supply
Posted on Oct 18, 2009
SOURCE:
CANON NP 7161 HOW TO QUALITY PRINT
Hi. Please be more specific and explain what you need so we can help you out , copies are blurred, darken or whiter?
Jan 30, 2018 | Canon Office Equipment & Supplies
Canon np 7161 photo copy machine error code 010
  1. If Cause of connector
All are The connector if not connected then Reconnect it.
2. Cause of Power Supply PCB.
Turn on the power switch. Set the meter
range to 30 VDC, and connect the probes to
J209-4 (+) and J209-3 (-) on the DC
controller PCB. Is the voltage about 24 V?
Suggestion:
See
"DC power is absent.Power Supply PCB is faulty
3. Cause Of Main Motor(M1) or DC controller
Replace the main motor. Is the problem
corrected? If no..Then
Replace The DC controller
Jun 30, 2016 | Canon Office Equipment & Supplies
Canon 7161 error 805
• The exhaust fan (FM2, FM4) is faulty.or
• The DC controller PCB is faulty.
See Chapter 10 page 101 of the service manual You can download the service manual for the Canon NP 7161 from here See chapter 10 page 101
http://monitor.espec.ws/files/np7161_sm_123.pdf
Dec 29, 2013 | Office Equipment & Supplies
E102 np 7161
If this is a canon copier then the E102 code means that the scanner lamp is bad or the laser unit is bad... Scanner lamp is a simple repair job for a tech. Laser Unit is a lot of labor. This can get expensive fast.
Canon Parts And Supplies
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Sep 13, 2012 | Compatible Office Equipment & Supplies
On Canon NP 7161: what's the 123 symbol flash mean? And the clear powder also flash but it new one empty. Please help
The "123" symbol is that you need to insert the key counter or you need to deposit a coin. It is a control funcation for using the copier.
Sep 09, 2010 | Office Equipment & Supplies
Canon NP 7161, auto exposure adjustment
WHAT KIND OF DETAILS?
You can calibrate the lamp under service mode * 28 (together for 3 sec) * i think under No.5.
Whe you open the front door, under instruction hoewto replace toner there must be an table with numbers and standard adj, values.By this table you can figure out which values do You need to change - something by my memory HL5 or similar value for lighter copy decrease value and oposite.
May 16, 2009 | Sharp AR-5316 Advanced Digital Imager...
A canon np 7161 with an e002 error code. It is my
ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, kibokoyao waiting for your vote.
Apr 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Canon np 7161 simulation
hi help me with this formula to reset canon 7161 e0003 is *2&8 at a go, then * then A then 412 is this the correct way. ?????
Jan 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Key boadrd problem in canon np 7161
If You trust me ... then do it i had the same problem after too much hard work i found the LEDs was causing the problems just trust me and replace all the LEDs on the panel card ....
and remember me in ur prayers thanks and regards
contact me for further
[email protected]
country Pakistan
Muhammad Ali
Sep 15, 2008 | Office Equipment & Supplies
Open Questions:
487 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
