Question about Dymo LetraTag QX50 Thermal Label Printer
My dymo only prints top half of word - Dymo LetraTag QX50 Thermal Label Printer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Try a new cassette. Otherwise, please contact our help desk. The numbers are at dymo.com.
Posted on Dec 16, 2013
2 Suggested Answers
  • 7 Answers
SOURCE: dymo label 400 turbo.
It doesn't use ink so that's not the problem. more than likely it's one of 2 things. 1. you created a custom label layout and the text is just over the edge of it's printable area. Therefore, only hal of it prints. #2 Your using the wrong size label template on the software. make sure that the size you have loaded in your label printer matches the template shown size for size, inch for inch. The printer doesn't know (or care) what label you have showing on your software. It only knows what's loaded in your printer. So for example, if you have a shipping label on the software and put text to the bottom og it, it won;t print if you have an address label laoded in the printer.
Posted on Dec 31, 2008
Dymo letratag blotchy print
Generally this is caused by something getting stuck on the print head. You can try a q-tip or a q-tip with pure rubbing alcohol on it and wipe of the print head.
Nov 06, 2013 | Office Equipment & Supplies
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
Paper "30252 address" is not supported
Here is the fix for Win7 provided by Dymo tech support:
1. goto Devices and Printers
2. select Dymo Label Writer
3. On the top where you see Print Server Properties, open it and find "30252 address"
4. delete "30252"
5. delete Dymo Label Writer printer
6. disconnect USB cable and then power to Dymo printer
7. connect power and then USB cable back to Dymo printer
8. reboot PC
9. try printing label again.
Jan 31, 2013 | Dymo LabelWriter Thermal Printer
My Dymo label maker is not printing all the letters clearly,half are missing
Try a different cassette. Otherwise, please contact our help desk. The numbers are at dymo.com.
May 08, 2011 | Dymo LetraTag QX50 Thermal Label Printer
My dymo letratag prints only bottom half of a name
Your cassette tape has probably become unthread. Take the cassette out of your handheld printer. Make sure that the tape is fed under both claws on each side of the tape. If the tape is only under one claw, your label will not be flat and will only print the bottom half of the letter on your label.
Jan 03, 2011 | Dymo LetraTAG Thermal Label Printer
Only prints bottom of words
in my opinion, if you have the package and docket it is always best to take it back and get it replaced, making sure you tell them when you attempted to print it would not print. many people i know have had no success repaqirin these.
Jan 04, 2010 | Dymo LetraTag QX50 Thermal Label Printer
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
My dymo starting printing only the bottom half of my labels, do i just need a new ink cartridge or is this a different problem? the bottom half seems just fine...
Take out tape cartridge, make sure tape is going THROUGH both top and bottom tape guides. Clear all.
This should work. You also may have set up for second line printing. Go through all settings and clear.
May 06, 2009 | Dymo LetraTAG Thermal Label Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo LetraTag QX50 Thermal Label Printer Logo
145 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
