Question about GE PSI23SCN Side by Side Refrigerator
My GE Profile Artica PSI23SCN refrig. temp on the refrig side stays at 27 degrees. I turned up the freezer temp to 6 and the refrig went up to 31. I called arepair guy and he said he had a client with the same problem. He replaced the sensor and the board and still did not fix it. Is there something wrong with the window vent between the freezer and refrig?
  • GE Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Apr 03, 2011
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Ge profile Ps27sgra refrigerator and freezef are
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS i REPLACED THE MOTHERBOARD AND IT STILL DOSEN'T KEEP THE PROPER TEMPERATURE. It varies from 36 to 45 degrees.
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Sep 26, 2009 | GE Profile PFCS1NJWSS Stainless Steel...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
My GE Profile bottom freezer and frig's temps are also up..help
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
Jul 20, 2009 | GE Profile Stainless Bottom-Freezer...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
GE PSI23SCN Side by Side Refrigerator Logo
144 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
