Question about Western Digital Computers & Internet
I have a WD Passport 5000, itwa working well till I found that I can't copy some files from it. I decide to move all file to another drive and I was left with a number of about 100 files that are not accessable. The file types are word,excel and pictures files. I am on an Windows XP system. Do You have a solution? Thanks
  • mhammam9 Apr 02, 2011
    When I move the file or copy it I get Data error (cyclic redundancy check)
    The file directory is accessable but some of the files in that directory have the above error when copied or moved to another media
    Thanks for your support
    Have changed the cable with no status change
    Have run the diag tools, the tool failed to continue with found bad sectors
    Have run chkdsk with 1006KB bad sectors
    Connection was made directly with the PC with no change.
    Do you have another sugestion?
    Thanks a lot for your support
    Genius:
  • 1,570 Answers
Hi
If cannot copy but you can open the file. I suggest you open it first and Save again to any destination folder you want. That will help solve your problem.
Another is try to copy one by one and not by bulky copying.
Make sure it is not write protected and surely you cannot copy any file at all. Maybe you have the auto lock write protect. To remove, press right click mouse and the option says unwrite protect.
If not try to install the WD software again to your computer. It might help you as well.
I hope it helps you this solutions. Regards
Posted on Apr 03, 2011
    Genius:
  • 1,098 Answers
Hi.
To be able to assist you better, may I know the exact error that you are getting?
Is the file directory not accessible itself or just specific files?
Thank you!
Posted on Apr 02, 2011
  • Ivy  Cada
    Ivy Cada Apr 02, 2011
    When something goes wrong with the data between the time it leaves the source and arrives at its destination you will normally see this kind of error. he most common times you will see the cyclic redundancy check error
    message is when trying to read data from a damaged CD or DVD or hard
    drive.
    Here are few things you can do:
    1. Try using a different USB cable. More often than not, CRC errors are usually caused by faulty USB cables.
    2. Scan your external HDD for error (right click the HDD -> Properties ->Tools - error checking). After finish try to copy again
    3. Run a diagnostic test. You can download it from here.
    4. Open Command Prompt and type CHKDSK. If you come out with errors, post the result here.
    5. If the files are important, you may want to connect directly the hard drive to the pc as a secondary hard drive
    • Remove the HDD from the enclosure and look at where you connect the IDE
      ribbon cable and the power cord in there in between them should be four
      sets of two pins.
    I hope this helps. Let me know what happens.
    Thank you!
WD External Hard Drive Passport Ultra Beginner's Questions
Usually with an external hard drive it's not necessary for it to copy over an existing backup or at least you can program your PC not to do this. What will happen is you will have several different copies of backup's and you will have to decide if you want to erase the others and keep the most resent one. Yes your file will be saved withing the backup but if you change the file name it will file this as a new file
Sep 28, 2015 | Ultra Computers & Internet
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
Hi , I just copied my hard drives to my new Passport Essentials SE using the WD Smartware software, I do not like I have to manually switch between my two internal hard drives to back up so I would like to...
As far as I remember WD just copies the software into the PassPort drives and you don't have to install anything you can just run the software from the drive. If that is still the case then first take a backup of that software (basically copy that software folder to some place in your internal drives) then format the drive (make sure you select NTFS as the file system for the drive when formatting).
Formatting will erase all the files in the drive so make sure you have backup of you personal files also.
Formatting also resets the drive back to factory setting (if you want the WD software back then just copy it from the backup to the PassPort drive).
Sep 06, 2011 | Western Digital WD Passport 250GB Portable...
I wanted to back up the files on my WD passport. Apparently I cannot move the majority of my files and there are some .exe and .inf files on my wd that are locked and not removable. my guess is that it...
Hi and welcome khaksh ,
Connect your passport to your lap .
Let your antivirus full scan the content of it .
Complete the scan with MalwareBytes , a powerfull malware killer :
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
To completely finish the job , have the content of your lap fully scanned by both applications .
When you are shure both pc and passport are virus free , try accessing locked files as administrator .
I hope this will help you .
Best regards ,
Feb 12, 2011 | Western Digital Passport 120GB External...
I'm not able to write files to my WD passport drive. It works fine in XP, but I have a Mac only..really not sure wat to do here..sos!
If the WD has been formatted in NTFS then the MAC cannot read or copy to this hard disk.
To make it compatible for the PC and MAC, format the WD Passport drive on your XP computer in FAT32 format. Then you can copy and exchange files between the PC and MAC.
Dec 26, 2010 | Computers & Internet
I have a wd used on a mac and would like to use it on a eepc as well, but it is not working...I can't open it on the eepc
The disk-drive might be formatted for usage _only_ with Mac OS X.
Copy all the files from it to your Mac's disk-drive.
Move the Passport to any PC, and "format" the disk for use by Windows.
Move the Passport to your Mac, and copy all the "saved" files back onto the Passport.
Move the Passport to your EEPC, and you should be able to use it, and to see the filenames that you copied from your Mac.
Dec 18, 2010 | Western Digital Passport WDXML800UE...
How do I restore my files on my passport to my internal hard drive
Why not make it KISS (Keep it simple and stupid). Go to your my Passport folders or files that you want to copy, Click on it and Copy (ctrl c) or Cut it (ctrl x), now go to your internal drive (C:\ or D:\,etc) and do Paste (ctrl V. You can also copy or cut multiple files or folders.
Sep 03, 2009 | Western Digital WD Passport 250GB Portable...
Cannot copy large files onto my WD passport
Your drive is probably in FAT32 format.  FAT32 has a 4GB file limit that is why your 5GB movie isn't saving.  You will have to format the drive in Mac OS file format (HFS) using Disk Utility.
Unfortunately once its in Mac format the drive will not be recognized by windows PCs.  What I do is have a program called macdrive installed on my windows computers so that they can access mac format hard drives.
i hope this helps!
Nov 13, 2008 | Western Digital Passport WDXML800UE...
WD Passport Drive Lights Up But Compu Does Not Find the Drive
No NO , WD is an excellent company as of 2004 , excellent products from them , if you wanna complain rag on seagate SATA drives hahaha they decided to dissable S.M.A.R.T. technology on their drives , yuck !
if the drive stopped working like that all the sudden , USE YOUR WARRENTY and RMA the drive back to the compay , get them to give you an RMA number , make up any sad story as long as the drive is still under warrenty , now they may ask you to pay for the new drive they send , but thats just untill they verify your old one is dead , then they'll refund the money back to your bank account.
which is totaly reasonable and protects them financialy , anybody would do the same.
You'te not alone , many many many DIFFERENT external drives are working one day and not working the next , it has alot to do with the batch , a particular batch of drives may be defective and nobody knows about it till it happens.... so please don't be real upset at maxtor or any others , but you can deffinately rag on seagate hahaha if just for their taking away the SMART drive diagnostics from their SATA drives .. we'll get you seagate Muhahaha we want our diagnostic tools because we're hardware monkies lol
so my advice is don't fight this too much , and RMA the drive back to the company if you still have warrenty power ...
they do have data recovery service , that may cost you more money , but you must decide what the data is worth to you , and maybe they will even get your data back for you if the drive was/is still under warrenty ,
always use your warrenty powers when you can.
shalom
Sep 10, 2008 | Western Digital Passport WDXML800UE...
WD passport Portable hard drive
right click on the folder and the menu will open. Highlite move file or send to and move it to yoour new drive
Apr 07, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
59 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
