Brivis wombat 92 central duct heating,pilot is on,fan constantly blows air out no heat at all just air,test button red light is on and buzzing noise. Please help.
2 Suggested Answers
SOURCE: Air blowing out - Pilot on but no heat.
Possibly overheating or previously overheated, these units are also prone to control box issues usually a buzzing noise at the unit it present if this is the case.
Posted on Apr 28, 2010
I have a brivis buffalo 85 ducted heating system, from last few days it doesn't come hot air only fan is running. pilot lamp also not with flame. ignation is working. I was turm blue color lid to pilot...
you need a new thermocouple. u can either get one from a plumbing store but the can be a bit fiddley to fit or u can get the proper Brivis one it just pulls out and u put the new one in. then u have to re light the pilot light. make sure u hold it down for at least 45 sec to make sure that it is getting hot enough when u release it it will stay alight then turn gas valve to the on position
May 26, 2014 | Heating & Cooling
Brivis wombat 2P 20
love to know how you went , i have a similar problem with the same unit.....
May 29, 2013 | Heating & Cooling
Pilot light is large and yellow on the brivis 92 wombat
blocked pilot , lack of air so it burns yellow needs blowing out with air line or can of air , or undo and clean pilot .
Jul 25, 2011 | Heating & Cooling
My brivis wombat 120 igniter won't work so I can't light the pilot
I have a brivis wombat 120. When room temperature is lower than required temperature, it starts to fire up and sends heating air. Now, it does start firing. If I increase the temperature testing, you can hear ant click sound from heater, but no firing. Can anyone help
Mar 26, 2011 | Heating & Cooling
Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
May 31, 2010 | Heating & Cooling
Brivis Upflow/Downflow fan on continuously, no heat
depending on the year of the unit
if its between 1992-1999 it would be caused by the either the pilot not staying alight, or a faulty gas valve not opening,
These models start the fan on a time delay not tempreture so you will only get cold air circulating and when the thermostat is off the fan will stop.
(All models) if the fan is running regardless of the thermostat position an over heat sensor is faulty.
May 17, 2010 | Heating & Cooling
Apr 28, 2010 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Heating isn't working, can't find the red button to relight the pilot
Many times the knob to turn the gas on on the valve is also the pilot knob. Turn it to pilot and hold it down while you light the pilot. Hold it for up to a minute and release. If the pilot stays on then turn it to on. If not you need a new thermocouple.
Apr 26, 2009 | Heating & Cooling
Heating & Cooling Logo
199 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
