Question about Veho Smartfix Slide Negative Scanner (VFS008) Battery
Where do I download a manual of veho smartfix scanner
    Problem Solver:
  • 9 Answers
The user manual should be on the CD that comes with the scanner. If it is not there the company has a download page for support here: http://www.veho-uk.com/main/downloads.aspx
Posted on Apr 05, 2011
INSTRUCTION MANUAL
To help you download the user manual for Veho VFS-002M Scanner, please find the link given below:
GuruAid.com
Apr 26, 2016 | Veho VFS-002M Film Scanner (35 mm)
Computer does not recognise Scanner -- why not?
How old is the scanner? did you read for what Windows version it was made in the first place?
If it is for an older OS then Windows7 and you are using Windows 7 or higher, you ran out of luck.
Always first install the software that came with the device. The driver needed for the device is supposed to be on the install disk.
You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
Oct 17, 2014 | Veho VFS-008 Smartfix Film Scanner USB...
Where can i driver download?
Go to the Veho Download Centre:
select "Drivers and Software"
then "Microscopes"
then "VMS-004 400x USB Microscope".
There are zip files for two versions: first download the pdf that explains how to choose the correct zip file.
May 01, 2014 | Veho VMS-004D 400x USB Microscope...
I need to use the Veho VFS-002m scanner on Linux. I can't find any way of installing it. Any ideas?
install a program called Cheese. works great but without software dpi interpolation
Jul 30, 2011 | Veho VFS-002M Film Scanner (35 mm)
Am trying to re-install my Veho 35mm film scanner after a PC "crash" but there is a problerm, the suggestion is I contact you for a solution, perhaps a site where I can obtain an update?, Regards, Rovert...
Hi there Robert!
Go to this site and download the "Download Centre"
http://www.veho-uk.com/support.aspx
That program will check your Veho 35mm film scanner for newer drivers, pathecs and updates.
Good luck Robert
Nic
May 28, 2009 | Office Equipment & Supplies
Veho Smartfix Slide  Negative Scanner (VFS008) Battery Logo
1,350 people viewed this question
Top Veho Cameras Experts
Are you a Veho Camera Expert? Answer questions, earn points and help others
