My computer doesnt boot
Hi
When I start my computer, monitor starts with green light but with in a second or two it turns read and screen remains black. Prior to this it was working fine and my CMOS battery was dead so giving me checksum4 error. So I had just replaced the battery and then started the computer but now it no longer works....please help......Ashish
  • Ashish_test Aug 07, 2008
    Hi Romy,
    Thanks for your advise. As such my problem was solved when I just disconnected the power cord and kept the system off for a day (I had also taken away CMOS battery from the slot so as incase of any bad memory storage everything is wiped out). Next day when I just switched on my computer and wow it simply started off showing me default checksom error (i.e. it appears when battery is down or it is not in place). I just defined the current date in Bios and started my computer. I let the XP (Os on my PC loaded) and then log off and switch off the system. I placed then my CMOS battery in. And now everything works fine.
    Anyway thanks for your advise.
    Ashish
    P.S. Crux of the problem was it was keeping bad memory in cache for more than half an our.
    Scholar:
  • 56 Answers
Hi Ashish
There is no problem with ur system board.
Actually you are getting this problem because of Monitor problem.
The possible cause would be:
1. Your data cable connecting your board failed.
2. The display IC of your monitor failed.
3. If you have Video card then remove video card and try connecting data cable to monitor port other than ur video card.
most probably u are dealing this problem due to failure of ur display IC.
Troubleshoot first by connecting other monitor with ur system if available.
gimme ur acknowledge by rating me
Thanx
Romy
Posted on Aug 05, 2008
When I turn on the power my E173FPb lights up for only one or two seconds and then goes black and the green on-light remains illuminated. try on other computers same thing, am i wasting my time fixing was...
Hi there! You can test first if the monitor is working. Disconnect it from the computer then turn it on after that it should show you colors on the screen this means its working if not then its no use trying it on a different computer.
Hope this helps!
Sep 06, 2011 | Dell E173FPb 17" TFT LCD Monitor
When i power on my pc,the monitor power indicator lights green but about 3s later it goes brown.the monitor screen remains unchanged as to when the computer was powered off.my email is...
You are not getting a video signal to the monitor. The fact that it is green initially shows it's working. When it turns orange, that's an indicator that it is getting no signal from the computer. So the next thing to check is if your computer is actually booting up or if your video card is going bad.
Do you normally hear a beep when the computer starts? Do you hear it now? If the answer is yes and no, then your computer is not starting up. To troubleshoot, I would suggest opening the case and disconnecting everything but the video, CPU, and memory. See if it starts. (you should get a message about no boot device if this happens)
If still no video, you have a hardware problem most probably related to the video card.
Mar 18, 2010 | Dell Computers & Internet
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Monitor is on when computer boots up , then turns off
You can email rhartze@key-services.com and provide your telephone number... he will call you to assist.
Dec 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
When the PC starts the monitor does not come out of the power standby mode
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Jan 16, 2007 | LG Flatron L1715S 17" LCD Monitor
Computers & Internet Logo
519 people viewed this question
David Payne
David Payne
