Question about HP OfficeJet J4580 All-In-One InkJet Printer
Will not power up. The on/off button does not work, however the attention light is red and when the cover is raised you can see the Scan sensor is light but is frozen in position. Will not respond to any button on the panel
  • HP Master
  • 17,129 Answers
The power supply is working but there is no feedback or response from the CPU board.
So it seems that the main board is faulty as you need to remove and check for faulty connectors , links or visible damaged components.
Posted on Apr 02, 2011
Trunk lights and automatic opener don't work, all fuses ok - 2007 E550
You must access and scan your onboard computer system to diagnose the fault.
Nov 26, 2011 | 2007 Mercedes-Benz E-Class
Hoover - Red Light Dirt Sensor
check to make sure the settings didn't get inadvertently switched to the hi position, move the switch back and forth from high to reg a few times, then leave it on reg.
remove and hand wash the primary filter and secondary filter, dry throughly and replace them in the vacuum.
if none of this works, you will need to have the vacuum serviced, or if it is still working, just don't pay attention to the dirt-finder. the dirt sensor on your vacuum is located in the suction tube and is generally not accessible enough to clean without taking the vacuum apart.
hope this helps,
trin
Nov 20, 2007 | Vacuums
Will not power up. The on/off button does not work, however the attention light is red and when the cover is raised you can see the Scan sensor is light but is frozen in position. Will not respond to any...
Hello, maybe you should take it back to the service centre of HP around you for repaire. Because that problem is from internal that i dont think you can attend to, please
Apr 02, 2011 | HP Office Equipment & Supplies
Printer sporadically displays a red light three successive flashes error and will not respond to till / keyboard. What does this mean?
PUT PAPER INSIDE PRINTER POWER OFF THE PRINTER.
THEN PRESS & HOLD THE BUTTON ON TOP OF PRINTER
BY HOLDING THE BUTTON NOW SWITCH THE PRINTER ON & WAIT UNTIL THE SIZE OF PAPER IS SCANNED .
IT WIILL BE DONE.
Feb 08, 2011 | Epson TM88II Thermal Printer
What does red triangle flashing light mean on the dashboard of a vauxhall vectra 1999 model?
I think that the light you're reffering to is the engine check light. You may find the vehicle has two....The red triangle will command attention and will probably be something important which needs urgent attention. I would suggest you visit your local shop and have a scan carried out on your vehicle....Best not to put it off....Regards Johngee
Oct 14, 2010 | 2006 Land Rover LR3
I had my dish installed to one tv. Now i switched out the tv for another one how do i get my dish to work with the new tv
Hi there this is Kimberly Escobar with DISH Network. I will be glad to help you by providing you the information that can help you. To program the DISH Network remote with your T.V we usually integrate a code into the remote that works with the brand of your T.V allowing our remote to function with the T.V itself by reading your post you don't mention the brand of your television but that is not a problem there is another way to help program your remote without having to use a code, it is called Power Scan in the Power scan procedure we search for the code that gets the remote to control your T.V. To perform a Power Scan your T.V must be on, you press and hold the T.V button until all the other buttons at the top light up in red. Once they light up in red you enter the number 500, you wait for the top buttons to go off and the you will press and hold once again the T.V button until the buttons light up again once you see them come on you will press the big red Power button on the remote once immediately after you press the big red power button you will press one repeatedly the channel up arrow one time after another until T.V turns off immediately after it goes off press the pound button (#) you should see the T.V button light up 3 times then try turning the T.V back on using the remote it should work. Here is this link http://www.dishnetwork.com/SupportSection/power-scan-instructions it shows you the procedures. I hope you find this helpful if you have any questions or need further assistance please contact us directly at 1800-333-DISH thank you.
Jun 25, 2010 | DISH Network IR Remote Control
I need to scan something but it won't let me until i change the ink. It doesn't use in to scan. I need to scan something ASAP.
Hi
Only maybe this will help, it for a canon printer but not same as yours but maybe it worth a go it just might work with other canons, Please can you get back to me if it works then I can gave this info help others
It a reset ink levels but as I say it for a different canon priter
1. Disconnect the power cable.
2. Connect it while holding down the "power" button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button.
5. The printer turns into factory mode: wait for about 10 seconds, then it says "Idle".
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning". A test page will print..
9. Open the cover, like you are about to change the cartridges.
10. Disconnect the power cable again.
11. Take out both cartridges.
12. Close the cover.
13. Connect the power cable once again.
14. Turn the printer on.
15. Put the cartridges back.
Let us know plese if it worked.
All the best: pineworks
Jan 29, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Red light 5 blinks
your set needs attention by the authorised service - probably the Vertical scan, horizontal scan or the flyback transformer driver circuits have failed.
Jul 12, 2009 | Sony KDS-R50XBR1 50" HDTV
I turn on my ps3 with the sensor button on the front the light turns green breifly then it goes out completely no lights or power
Pay really close attention to the led lights.
Do they go red and yellow as well for just a brief brief second?
Jun 15, 2009 | Sony Playstation 3 (PS3) Console
Flashing red button with a triangle and ! in it . printer won't work
If only the attention light is flashing then follow the guide below -
The Attention (amber)
light is blinking.
Attention error. The top
cover is open.
Close the top cover.
printer is out of media.
Load media.
printer has a jam.
1. Clear the jam (see pages 164 through 168).
2. If the location of the jam is not apparent, check
the embedded Web server to find the jam
location.
 If the jam was under the imaging drum, toggle
the registration sensor to check its movement
and replace the registration sensor if it does not
move freely.
 If the jam was in the fuser area, toggle the fuser
exit sensor to check its movement and replace
the fuser exit sensor if it does not move freely.
Jun 07, 2008 | HP Color LaserJet 2550n printer + HP Color...
HP OfficeJet J4580 All-In-One InkJet Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
