Question about Canon PIXMA MP170 All-In-One InkJet Printer
I have just changed cannon 40/41 empty, for full but the colours are not as good as i hoped,am i doing somthing wrong. the instructions i got with the new cartriges has gone walkabout can you help
  • 122 Answers
Hello, If you followed the instructions that were giving as it where, then it should comeout clear but if not you have to change the catridge.
Posted on Apr 02, 2011
Why is my dcp135c printing images in brown instead of black
Several probable causes of this.
  1. Your Black is empty and the printer is trying to approximate the Black using the other colours. Check and replace Black.
  2. Your Black printhead is blocked and all you are seeing is the other colours that are used to make the black into a full black. Check cartridge and do a printhead clean to see if this clears it. Also print off a print quality test sheet (In the Ink Management options on the printer)
  3. Another colour has been put into the Black Slot on your printer. Replace the incorrect cartridge and hope that the printhead has not been damaged by using the wrong cartridge. May need several printhead cleans to clear incorrect ink from the feed lines.
Hope this helps.
Oct 07, 2014 | Brother DCP-135C Flatbed Digital MFC...
There is a red light flashing beside the triangle symbol on my cannon lbp5050n. What does this mean?
Hey!
If that happens look in the system tray for a yellow tiangle,click on it and it will tell you the problem!It might just be a empty toner!
Hope it helps!
Jun 28, 2011 | Canon LaserShot LBP5050N A4 Colour Laser ,...
I do not need to print color documents. Will it print if I only replace the black cartridge and not the color cartridge?
you must have both cartridges fitted for the printer to work. The colour cartridge can be empty if you don't want to print any colour, but it must still be in there. When the ink monitor prompts you to replace the colour cart, just lift it out and push back down. This will reset the ink counter.
This is ok to do in emergency, but not a good practice as you'll end up with colour printhead full of air. If you're doing this to save ink, just buy some generic colour cartridges, they're quite cheap.
hope this helps
LC
www.inkbank.com.au
Nov 12, 2010 | Epson Stylus Color 740 InkJet Printer
The ink wont work do i have to have coloured ink as well for the printer to work???
no it is not necessary to coloured catridge .but the two spots should be filled with an empty or new catridge. if this is not woking open the catridges and check
Sep 17, 2010 | Cannon Office Equipment & Supplies
Cannon mp180 ink reservoir full
If you do a google search on this you will find all the instructions you need to sort it out. - you will get ink all over your fingers though.
Sep 10, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Cannon i865,(no colour printing)
Hi all of you
you have to open the printer setting dialog box , thereby a check box set it off.
Hope this fix your problem
thanks
Hamedo
Nov 21, 2008 | Canon Office Equipment & Supplies
My colour ink catridge is empty, but I do not want to use it. Is there a way to overide using colour ink?
You can go to the printer settings (Start, Printers and Faxes, rightclick on printer and click Properties).
Click on Printing Preferences and in there should have a setting to print Black & White only.
Thanks,
Lolita
Apr 09, 2008 | Office Equipment & Supplies
Coloured And Dotted Lines Across My Screen
Firstly, start your pc in safe mode (f8) on boot up. This will start your pc in vga mode, and hopefully the lines are still there, which will indicate a faulty graphics card, if they aren't it may be a problem driver. If no lines, go to Add/remove programmes and uninstal your graphics driver. Re boot pc then when it finds your card make sure you point Windows to the folder in which you have saved the driver files. The driver should then install, see if any change. You may have to try some older drivers, as Nvidia can be awkward at times. I have had varying problems with Nvidia and replaced with ATI cards with no problems.
Dec 01, 2006 | XFX GeForce 6200 Graphic Card
Canon PIXMA MP170 All-In-One InkJet Printer Logo
18 people viewed this question
old marine
old marine
