Question about Acer X1230 DLP Projector
Fan fail error. projector shall shut down automatically
  • Anonymous Mar 13, 2014
    turn on and after few minutes it turn off automatically and led error indicadets a problem fan fail error.
  • Acer Master
  • 17,130 Answers
If the Fan fails the temperature goes up and so the temperature is detected to be high to cut off the projector.
Please replace fan or correct the power to the fan.
Posted on Apr 02, 2011
My optoma758 projector switches of after a few minutes&the lamp light flicker red@1second
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Dec 05, 2016 | Office Equipment & Supplies
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
Acer x110 fan fail
fan fail will system automatic shut down soon how i removed this error
Nov 24, 2013 | Acer X1230 DLP Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
When I start the projector Dell M409WX..lamp lighten properly but one msg comes as "Fan Failed" and it gets shutdown. A blinking amber TEMP light indicates that the projector fan has failed and...
Well this is actually an error message that indicates that either the fan is actually failing or the temperature sensor, and or thermostat arrangement are faulty and need to be repaired.replaced
This isn't a too uncommon event.. Hopefully it will be a temperature sensor fault, and a replacement will sort the problem out?
If you wish to DIY, then you will need to obtain a service manual, (I have had a look on the 'net and have been unable to find one, so you may need to approach the manufacturers direct?) to enable you to order the faulty parts by number, and also how and where to locate the faulty parts and remove/replace/repair.
It maybe best though in my professional opinion, to contact a local or head office from Dell, and ask for a referral to an authorised service center. When in contact here simply first only ask for a "Quote" as to the prospective repairs and costings etc, and go from there? This way one can make an informed decision, at the least.
Aug 02, 2011 | Dell M409WX Projector
Projector will only stay on for a couple of minutes then shuts off automatically. the LED turns from green to red
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Oct 28, 2010 | Toshiba TDP-T90 Multimedia Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
Fan Failure Error
the temp sensor probably wore out when the fan did. just replace the sensor. usually located on the lamp housing or near the fans. looks like a transistor.
Sep 28, 2009 | Eiki LC-XG210 Projector Multimedia...
LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Oct 01, 2007 | BenQ PB6100 Multimedia Projector
Acer X1230 DLP Projector Logo
7,141 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
