Question about Sony PlayStation Portable (PSP) Console
Internet i have set up the internet settings and when i tested my connection there was no problems. but what do i do now, because i cant use internet without a 4 digit code but i dont know how to get one. any ideas ??
Ring your internet servace
Posted on Aug 06, 2008
Cant connect my xbox to the internet to play on line
First you need a house internet connection. Check if your xbox is connected via a Ethernet cable or wireless router. After you finish go to console settings and do a connection test.
Jun 27, 2011 | Microsoft Xbox 360 Arcade (4 GB) Console
Cant put the wi fi on my wii
Wireless Connection: Step 1: Turn on Wii
Step 2: Select the Wii button on the left side of main menu.
Step 3: Select "Wii Settings"
Step 4: Scroll until you see "Internet" and select it.
Step 5: Select "Connection Settings"
Step 6: Search for an open connection by "Connection 3:None button"
Step 7: Select "Wireless Connection" and search for access point.
Step 8: Choose the access point desired from the list and save the settings.
Step 9: Test your connection. If successful you are connected to the internet if not go back and check your connection settings.
May 08, 2011 | Nintendo Wii Console
Cant connect to wireless on ps3
  • 1 Make sure your wireless Internet connection is active and at full strength. Unplug the PS3's Ethernet cable if it is plugged into the system.
  • 2 Turn on the Playstation 3 game console and select "Network Settings" under the "Settings" option in the main menu.
  • 3 Select the "Internet Connection Settings" tab and select "Yes" when the system displays a new screen saying you will be disconnected from the Internet.
  • 4 Select "Easy" on the next screen that asks what type of installation you want to use.
  • 5 Select "Wireless" when it asks you what type of Internet connection you have.
  • 6 Select "Scan" on the next screen.The system will search for all available Internet connections in the area.
  • 7 Select your home Internet connection when the screen pops up displaying the available Internet options. Select your security settings and enter your encryption key. Save your settings.
  • 8 Test the connection by selecting the "Test Connection" option. If the connection has been made, your network information will appear on the screen.
  • Mar 07, 2011 | Sony Playstation 3 (PS3) Console
    I cant connect to the yahoo messenger. my ie browser cant connect to the login.yahoo.com. however i can connect with opera browser. what can be the solution to my problem?
    Hey!
    Yahoo Messenger relies on Internet Explorer for its connectivity settings. It could be possible that some IE settings where changed.
    Try checking on the proxy settings.
    Here's how to go there:
    Open Internet Explorer
    Click on Tools
    Click on Internet Options
    Click on the Connections Tab
    Click on LAN Settings
    You will see 4 checkboxes, all boxes should not be checked
    After correcting settings, just click on OK
    Hope this helps! :D
    Sep 09, 2010 | Yahoo Mail
    Cant sign in to wlm
    If you can't sign in to MSN Messenger, the connection settings in MSN Messenger might be preventing you from connecting to the Microsoft® .NET Passport or Microsoft® .NET Messenger Service. The MSN Messenger Connection Troubleshooter can often find and fix these problems. The Connection Troubleshooter starts automatically if MSN Messenger encounters a connection problem. If you choose not to use the Connection Troubleshooter, or it does not solve your connection problem, try the following:
    1. Click the Tools menu, and then click Options.
    2. In the left pane, click Connection.
    3. Under Connection Settings, click Test Connection.
    If you agree to allow the Connection Troubleshooter to examine your system, it will test for connection problems and report steps you can take to correct them.
    4. Optional: Perform advanced troubleshooting
    To troubleshoot your specific type of connection, click Advanced Settings. On the Advanced Connection Options dialog box, check that the settings for your particular connection type are correct. To test your connection, click the Test button. Click OK, and then click OK.
    5. Click OK.
    When you choose these settings, MSN Messenger will use the Microsoft® Internet Explorer connection settings if possible.
    6. Try signing in to MSN Messenger again.
    Hope I helped MSN expert Dr Reed
    Sep 16, 2009 | Microsoft Windows Live Messanger
    I cant connect to friends on xbox live, how do i fix this prob?
    go to the dashboard then go to console setting then test connection and test it, if you dont have a connection you cant connect if you do your all set, to fix you whole internet connection you might have to call your isp(internet service provider). hope this helped
    Jul 12, 2009 | Microsoft Xbox 360 Console
    Xbox 360 Ethernet Connection broken
    sometimes you cant run you will need to adjust your network settings call 1-800 4 myxbox they can help
    Sep 15, 2008 | Microsoft Xbox 360 Console
    Wireless router wont connect
    Hey mentalmc,
    I had this problem at least once a month. Try these things out.
    1. Make sure any WEP codes are entered EXACTLY as it is for your router.
    2. Set up your router so only your PC connected to it can change any settings.
    3. Turn off your PC while trying to connect via PS3 WiFi. The good ole Win update likes to download without you knowing it sometimes.
    4. If all else fails, call Sony cause you may have a bad WiFi antenna or motherboard.
    Jun 25, 2008 | Sony Playstation 3 (PS3) Console
    PPPoE over Edimax BR-6104K without a modem
    HI,
      Actually in short  "you NEED A MODEM;"
    In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
    this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
    Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
    Sony PlayStation Portable (PSP) Console Logo
    32 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
