Question about Motorola Mobility Defy Cell Phone
Cant switch off standby for radio. it is killing my battery
  • 17,129 Answers
Possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation.
Posted on Apr 02, 2011
1988 celebrity.pushed the cigarette lighter in and the radio quit. Just motor noise coming from speakers. Put new fuse in and still the same. Did I kill the radio. How do I remedy it.
You replaced the cig lighter fuse ?
That should have fixed the radio problem if the lighter circuit has power now. Keep in mind when you kill the radio memory it resets to AM and not on any pre-set station. Just like when you disconnect the battery cable.
The radio gets memory power from the cig lighter circuit and regular power from the radio circuit thru the key switch.
Dec 14, 2015 | Cars & Trucks
Kill switch on amc explorer 13 33
whats your question because all I am reading is how your boy tore stuff up and we cant even get a deffinition of what he did tear up
Dec 29, 2013 | Garden
I have a 2013 Sonata and the radio won't turn off when the car is off. It won't allow me to power off the radio manually...help...it's going to kill my battery!
Check the door ajar switch that turns the radio off when you exit. Try opening the passenger door instead of driver door and see if the radio goes off, if so the switch in the driver door is defective.
Aug 25, 2013 | Hyundai Sonata Cars & Trucks
1993 BMW E36 325i odometer and clock won't turn off and kills my battery
fit a battery isolator inside the car under the dash on the battery earth is the cheapest soloution.Or a wiring diagram to trace the wires to locate the fault which i suspect could be on the radio wiring where 2 feeds are used one a permanant 12v feed and one a switchable feed via ignition switch causing a backfeed if done wrong .
Sep 22, 2012 | BMW X3 Series Cars & Trucks
How do I get power back to my 1995 maxima bose radio?
By running a another wire to the radio system,with another "KILL"switch on it. The wire and switch they installed kills all power from the battery,,run another from Battery to stereo,with a Toggle switch to kill Stereo power also when not in use,
Jun 07, 2012 | Frontier 2000 00 W/bose Replace Radio...
2001 suburban. abs pump killing battery. abs disconnected. starting to kill battery again. removed abs fuse, can/should I remove the EBCM fuse too?
YOU HAVE TO HAVE VECHICLE TOWED IN TO A GARAGE ONLY THING YOU CAN DO IS TURN OFF RADIO TO KEEP FROM LOSING THE CODE, THEN DISCONNECT THE NEGATIVE BATTERY CABLE TO KEEP FROM DRAINING THE BATTERY.IF YOU DISCONNECT ABS BRAKE MODULATOR UNIT FUSE AND RELAY YOU CANT DRIVE VECHICLE UNTIL TOW IN FIX,YOU NEED DIAGNOSTIC EQUIPMENT TO FIX VECHICLE.NOT A HOME FIX.
Jul 29, 2011 | 2001 Chevrolet Suburban
My mb525 uses abt 50 pct of the battery using standby radio. the radio app is off but still using battery. i can not find how to kill the fm radio. assistance is appreciated.
HI.
You can easilly kill the process by acessing the taskmanager in droid. This will expose the process so that you can kill the program.You can hold the home button to pull up the recent task window, then, touch the task manager button to access the running processes in the background to kill what you need to kill to preserve battery life.
Apr 02, 2011 | Motorola Mobility Defy Cell Phone
Cant get my 50cc scooter to fire up-no spark. any
  • Do you see spark? If not, check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the side stand kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it.
  • Is the handlebar kill switch on? Is it shorted out?
  • Check the fuses.
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires?
  • Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center or side casing.
  • If still no spark, get CDI system and coils checked at the dealers shop.
Aug 14, 2009 | 2005 Suzuki RM-Z 250
Cant get a spark from ht leads on cb250 motor bike
Be CERTAIN the battery is good. Are all fuses good? Try brand new spark plugs. Disconnect the kill switch on the handle bar. Check the side stand kill switch for proper operation. Have the shop check the CDI ignition.
Please rate this solution. Thanks!
Apr 01, 2009 | Honda CB 250 Motorcycles
Geo tracker lights and radio not working
power loss.
any good car elect. tech find this pronto.
just takes a volt meter to find the voltage drop point.
top fails:
1: corroded fuse box on right front finder (under fuse box)
2: did you say it kills motor too. cant figure above.
what about heater fan, it uses tons of current.
as does HL followed by tails.
20amps, 15amps and 5amps respectively
you have resistance some where.
and load , kills the voltage .
for me.
i'd:
check battery voltage , when it dims out.
then of ok 12.5v is ok key on,not started.
then check voltages at a right fender , fuse panel
all points there, 12.5vdc , same as battery v.
if OK
then
check voltage at the fuse above right knee
with load full, hl, fan, brakes, just key on.
now you know what circuit is fail ing by now.
report back with this facts.
Oct 16, 2008 | 1991 Geo Tracker
Motorola Mobility Defy Cell Phone Logo
128 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
