Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Hi please can you help me to resolve my problem with a bizhub 35 it's get me a code number c1183
  • 794 Answers
Hi elfethi,
This code c1183 is commonly caused by trays in your finisher which are not fully inserted into it's slot. It indicates an elevator motor Ascent/Descent Failure. You may want to try follow these steps that help you address the concern:
1. Check the output bin trays which are at the far left side of your machine.
2. Make sure that they are properly installed into the holders.
3. Then refresh your system by turning it off and on.
4.After doing these, the error should be gone.
If you're still getting the error after making sure that trays are properly installed then this means that the issue is already with the sensors or elevator motor. You will need to contact a local repair man.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 02, 2011
    Master:
  • 354 Answers
To reset a trouble code power the machine OFF/ON using the main switch while pressing the Utility key, then follow the LCD prompts.
Require technical support? Please call 1-800-208-1203, select option 4 and have your serial number available.
Bizhub 222 how to open elevator section
Check the exit sensor on the elevator tray (paper exit unit).
Jan 01, 2013 | Konica Minolta Bizhub 222 Black and White...
Bizhub 423 c1183 error code
id someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the trays has to just touch them.
Oct 10, 2012 | Minolta bizhub 200 All-In-One Printer
C1183 error the trays desent and rise normaly put the stapeling unit coms at the front? this must be in center? thanks if anyone can help bart
Hi
Error code C1183 means finishing option elevator drive malfunction. It appears due to tray lift motor failure on the finisher. To trouble shoot the issue turn off the power and open the elevator section to check the elevator motor. Wait for 2-3 minutes and check if the issue is resolved. If this doesn't work then check the alignment of front and rear rollers of the finisher. Also make sure that the finisher exit guide rollers are fine & the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. Sometimes this error may appear due to a broken lower gear by the pin slot. Hope this helps...
Daniel
Oct 09, 2010 | Konica Minolta Office Equipment & Supplies
BIZHUB 350 C1183 MALFUNCTION
Hi richard_hutc,
It would appear that you have an issue with the finisher/sorter on the side of the machine.
Specifically, C-1183 means the elevator motor hasn't ascended or descended correctly.
Open and close the finisher and look for any paper jams in this area.
Good luck
Jan 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 erro code c1183
C1183
Elevator motor ascent/
descent drive failure
• The elevator tray lower limit sensor (PC13) is not turned ON
even after the set period of time has elapsed after the main
power switch is set to ON.
• The elevator tray home position sensor (PC11) and elevator
top face detection sensor (PC12) are not turned ON even
after the set period of time has elapsed after the elevator
motor (M11) is energized.
• The elevator tray does not stop at the position for the specified
tray after the elevator motor (M11) is energized (beginning of
descent operation) and the elevator tray lower limit sensor
(PC13) is turned ON.
• The elevator top face detection sensor (PC12) is not turned
ON even after the set period of time has elapsed after the elevator
motor (M11) is energized (beginning of ascent operation)
when paper is being fed out.
May 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
BIZHUB 350 THROWING CODES C1183 AND NOW SHOWS C5351
C1183 Finishing option elevator drive
malfunction
See FS-514 Service Manual.
See P.65
Mar 31, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
Bizhub 200 fault code c1183
Its an elevator ascent/descent motor failure. You didnt by any chance have any thing such as a big box of paper or a trash can sitting under the exit trays did you? Check it to make sure the trays are level also.
Feb 27, 2008 | Minolta bizhub 200 All-In-One Printer
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
534 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
