Have tried using codes 0077, 0043 and 0056 as set out on page 16 of instructions of BT vision booklet. These are not working, at step 3 the blue light flashes TWICE. Understand that there are other codes.
    Master:
  • 354 Answers
If it flashes twice usually means it has reconized the code and now linked up. You might want to go over in booklet and make sure you are following procedures,if all else fails go to scan mode and do it that way ,just read on you'll seee
Posted on Apr 02, 2011
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
Codes for tuning bt vision box to sanyo tv
Here are the codes:
First try the 4 digit ones:
0136, 0242, 0722, 0732.
Now try 3 digit ones:
106 154 155 156 157
160 208 210 216 267
275 282 316 319 320
322 360 0236, 154,182 ,190, 191, 220, 221, 278, 282, 283, 323.
Goodluck..
Feb 14, 2008 | Televison & Video
I have a john Lewis remote that won't work my Bt vision box, despite the codes which I have entered from the instruction manual
I recommend that your contact the company cables, and consult if the john lewis control is compatible witht Bt box.
They will instruct if this will be work. Otherwise you must replace by other remote such as R.Schack that work very well.
sincerely. God bless you
May 06, 2012 | Televison & Video
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
Mar 06, 2012 | Televison & Video
We have a schneider tv and a bt vision box we have used a grey remote from bt but we had to have a new remote as ours went faulty we have tried all the codes from bt but unable to programme the new one to...
The remote control should have come with a leaflet/booklet containing a table of figures; these are the codes you need for your tv.
Failing this, check the leaflet/booklet for instructions on how to search for the code, using a key sequence on the remote; this is a long, drawn out process, but it may just work.
If all else fails, try using google to search for any web pages that may offer you the necessary code.
It might be worth the time involved to search the web for an answer.
Beyond that, contact the manufacturer of the remote control & ask them for the correct code.
In my experience, there are only a small number of tv manufacturers whose products are difficult to use with universal remote controls, but Schneider is an obscure make, & if it turns out to be not possible to link up the remote control, you may want to consider buying a new tv, but check that it will work with the remote control, before buying it.
Hope this has been of some help to you.
Thanks,
Steve.
Oct 01, 2010 | Televison & Video
Making a booklet out of a multi-page PageMaker file
many questions, the answer should be yes and all is in the driver settings but it all depends on if you have the correct driver installed and configured correctly for your copier and if your finisher is a booklet finisher. if you have every thing laid out in page maker correctly and the driver is setup correctly then it should do just fine.
Apr 14, 2010 | Canon imageRUNNER C3170U Color Copier
Bt vision remote
www.remotecodelist.com .....................................T.
Mar 20, 2008 | Televison & Video
Remote control
the code for the bt.vision box remote to work a durabrand tv is under the emerson range the code i used was 004 it works fine
Oct 10, 2007 | Durabrand DU1901 TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
