Question about HP Photosmart C5280 Printer
The following print cartridge has a problem: Black Refer to printer documentation.
  • HP Master
  • 32,281 Answers
Check the WEcam settings. Most WEBcam have a setting toinvert and mirror the image
Posted on Apr 02, 2011
  • 537 Answers
SOURCE: Print Cartridge Problem- HP PSC 1513
which cartridge is giving you problems? The one on the right? I think that is, IIRC, the black ink. Is it out of ink? If so, go to OfficeMax or Walgreens and have it refilled, or buy a new one. If it is clogged, then run your toolbox utility to clean it.
Mike
Posted on Feb 25, 2008
technotech
  • 183 Answers
SOURCE: I cant get my printer to print
Step one:Clear any paper or carriage path obstructions
Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed the instructions for removing a paper jam, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams.
Moving the carriage
With the all-in-one turned on, open the print cartridge access door. The print carriage might try to come to move into the access area. Allow it to move to that position if it does.
Without turning off the all-in-one, disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the parts to be moved by hand and to reset the paper feed mechanism.
Looking in through either the print cartridge access door or the output paper tray, verify that the print cartridges are locked into the carriage and have not come loose. Also verify that there are no obstructions under or around the carriage to block it from moving.
Verify that the print carriage can move freely across the width of the all-in-one by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
Close the print cartridge access door and reconnect the power cord.
Press the On button to turn on the all-in-one.
Print the self test from the menu to check the functionality of the product by following these steps:
*Press Setup , press 2 , and then press 6 in sequence. (The printer should be in ready mode.)
If the self test printed in the step above, then try to print from the computer to see if the issue is resolved.
* If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
* If the issue is not resolved , continue to the next step.
Step two: Plug the product directly into a wall outlet
Verify that the product is properly connected to a suitable power source by following the instructions below.
Verify that the computer and the all-in-one product have a three-prong power plug.
Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
Try the print job again to see if this step resolved the issue.
NOTE:If the product prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
Step three: Ensure that the control panel faceplate is installed correctly
If the control panel faceplate, or bezel, is incorrectly installed, the product may indicate a false carriage stall or carriage jam error condition. If the product has not been set up before, make sure the control panel faceplate is installed correctly by following the instructions below.
If the control panel faceplate is already installed, and your printer has been working for some time, do not attempt to re-install the faceplate. Press firmly on the faceplate to ensure proper installation of the faceplate adhesive or pins.
NOTE:If the control panel faceplate is already installed, proceed to the next step.
Attach the front panel covers.
Align the faceplate over the buttons on the top of the HP All-in-One.
Figure 1: Aligning the faceplate
Snap the faceplate firmly into place.
Figure 2: Attaching the control panel faceplate
Make sure all the buttons can move freely.
Step four: Perform a partial reset
A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
With the unit turned on, unplug the power cord from the unit.
NOTE:Do not do a partial reset when the printer is turned off.
Press and hold # and 3 while plugging in the power cord.
When Part.NVM Reset displays, release both buttons. The unit gets reset and comes online.
Step five: Remove and re-install the print cartridges
Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure that the cartridges are installed correctly by following the instructions below.
Turn on the HP Officejet, and open the print-carriage access door.The print carriage will move into the access area.
Figure 3: Opening the print carriage access door
After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
Figure 4: Removing the print cartridge
1 - Print cartridge slot for the tri-color print cartridge
2 - Print cartridge slot for the black and photo print cartridges
NOTE:It is normal to see ink buildup in the print cartridge slots.
Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Close the print cartridge access door.
Step six: Service the printer :- If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Nov 01, 2008
yooperbud
  • 8637 Answers
SOURCE: I have a HP Deskjet F380 All-in-One. Error light keeps flashing.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
jilpeshpatel
  • 259 Answers
SOURCE: My printer HP OfficeJet J4580 not printing I have
HP 4500 Chip Rs.1050 /- only change the chip and after printer is working fine
E-Mail:support@compudesk.in
Posted on Jul 14, 2009
  • 21 Answers
SOURCE: cartridge error
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd9
Posted on Sep 06, 2009
I replace my cartridges it says refer to printer documentation and will not print
These types of severe HP 74 black or HP 75 color ink cartridge errors (i.e. refer to documentation / incompatible cartridges, print cartridge(s) problem, etc.) typically indicate the internal micro electronics of the respective HP 74 black or HP 75 color cartridge are damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal micro electronics failure. I suggest you first run a Tap 41 diagnostic test to check cartridges electrical health (this is a special forced service test, refer to video so you understand how to read the print out). You may also bypass the error (temporarily) on most models which use HP 74/75 cartridges.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
CONTACT CLEANING / SERVICE TEST DIAGNOSTICS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test page should print. The printed pattern will verify printer is generally functional
--- The self test page is a 'forced' test print whether the ink cartridges are good or bad. Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
C. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure or .pdf document at the following links on how to activate and read the service test report: http://inkjet411.com/?page_id=536
1. Load Letter/A4-size paper into paper feed tray.
2. If any lights are blinking, first press Cancel to attempt to clear.
3. Press and HOLD the Cancel button, press Ok button once.
4. At 'Mfg Commands' menu, click Right Arrow once until 'uiaux service' menu is displayed.
5. At 'uiaux service' menu, click the Right Arrow until Special Reports menu is displayed.
6. Select Ok, then click Right Arrow until the 'print-mech button tap' menu is displayed.
7. Select Ok (Code = 0 will be displayed); click and hold Right Arrow until 'code = 41' is displayed. Use the Left Arrow if you need to decrease numerical count.
8. Select Ok. Within one minute the Tap 41 diagnostic test report should be initiated and print (whether ink cartridges are good or not, i.e. this is a forced print test). See following 4 paragraphs (or video) on how to interpret diagnostic report.....
NOTE: You may also refer to this document for specific printer model 'Tap 41' diagnostic & 'Cartridge Error Bypass' step-by-step instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 75/75XL color cartridge should display 600 good nozzles, while a good HP 74/74XL black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout.
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
ERROR BYPASS OPTION (TEMPORARY ONLY):
NOTE: It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only), please refer to link above/below for video/documentation instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
However, if the cartridge is determined to be electrically damaged, largely dependent on the 'Tap 41' diagnostic test results, the cartridge will eventually need to be replaced with a new one. With a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced.
*Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active electrical state of both cartridges.
For additional printer diagnostics information please visit: http://inkjet411.com/?page_id=1813
NOTE: If you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (with ink compatibility or color output/richness) with all of these models: http://inkjet411.com/?page_id=3585
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors. We do NOT suggest refilling these types of ink cartridges.....refilling of HP 74/75 original/genuine ink cartridges is only suggested!
HP 74/75 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=WqnHRFpbo0w
If you ever need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty and free shipping over $20 (products available to US residents only).
HP 74 Cartridges:
https://inkplicity.com/shop/?slug=advanced_search_result&keywords=HP%2074
HP 75 Cartridges:
https://inkplicity.com/shop/?slug=advanced_search_result&keywords=HP%2075
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
May 21, 2015 | HP Photosmart C5280 Printer
Black cartridge problem device documentation. HP Officejet 4500
This type of HP 901 ink cartridge error ("Refer to Device Documentation", etc.) condition is likely an internal micro-electronic failure inside the HP 901 (or 901XL) black ink cartridge. These failures typically occur due to natural degradation of internal micro-electronics over time and can occur with brand new ink cartridges.
To confirm root cause and check the internal electrical condition of both black and color ink cartridges, please execute the 'Tap 41' cartridge's electrical diagnostic test below (refer to procedure B).
CAUTION: Be advised, the use of remanufactured ink cartridges is considered somewhat unreliable since the cartridges are already on their 3rd life when purchased new (off the internet or at select retailer stores). As well, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors.
NOTE 1: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC CHECKS:
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to 2nd video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=620
a. Load Letter/A4-size paper into paper feed tray.
b. If any lights are blinking, first press Cancel to attempt to clear.
c. Press the * and # keys simultaneously.
d. Enter 124 at keypad. The 'Underware' menu should be displayed.
e. Use the arrow keys to navigate to the System Menu. Select Ok.
f. Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Printer screen should display "code = 0".
g. Use the arrow keys to enter "code = 41" (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern prints.
--- Providing the HP 901 (or 901XL) color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health - the printer will attempt to print the diagnostic test print). A good HP 901 color cartridge should display 1248 good nozzles, while a good HP 901/901XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the diagnostic test print: http://inkjet411.com/?page_id=620
For more diagnostic tests and error bypass procedures, please visit the Inkjet411 support center: http://www.inkjet411.com
Hopefully this helps....
Sep 12, 2013 | HP Officejet 4500 All-in-One -...
I got 3 months ago message on hp officejet j4580 display: Print cartridge problem: [Tri-Colour]. Refer to device documentation to troubleshoot. Today while printing a document, i noticed printing with...
You must be using HP60.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP4580 is pretty new model and has not cause major problem.
Good practical and durability is good.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Office Equipment & Supplies
When I print, the black ink skips or sometimes doesn't print anything. I put in a new cartridge (no improvement), manually cleaned printer head, tried to manually align printer and it says alignment...
unless you are printing and choosing black only, the printer uses the color cartridge also. Go into advanced settings and choose black only. If not you may try and replace the color cartridge, or return the cartridge, it might be defective.
Jan 15, 2011 | HP OfficeJet K80 All-In-One InkJet Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Refer to printer documentation error message
I kept having the same problem as what was experienced by gobigforgod. What should I do ? Pls help.
Mar 26, 2009 | HP Photosmart C5280 Printer
Jan 04, 2009 | HP DeskJet F380 All-In-One Printer
HP Photosmart C5280 Printer Logo
309 people viewed this question
Seeker5211
Seeker5211
