Question about Vacuums
How do i change the pin code onmy Comelit 8241S electric gate? Lost th manual.
We have a bissell lift-off deep cleaner 66e1 and it won't suck up the dirty water what can I do to fix it
Loss of suction power -
1. Tanks may not be seated properly - Pick up both tanks and reseat them so they fit properly on the unit.
2. Nozzles may not be assembled properly - Unplug the unit. Check to make sure the "lip" of the nozzle cover is securely hooked into the groove on the top of nozzle.
3. The portable spot cleaner is not attached completely - Push down firmly to check connection
4. Dirty tank has picked up maximum amount of dirty water and has reached full line - Empty dirty tank
5. Formula & water tank is empty - Check fluid levels in formula & water tank Suction Gate is open Check to make sure the suction gate is closed. Follow "Cleaning Suction Gate" instructions in the manual.
I hope this helps!
Jim
May 27, 2016 | Bissell Vacuums
My pooch decided to relieve its self onmy dyson . It now sparks near the roller. Is it repairable
well.... I suggest you kill the dog, LMAO. Disassemble the unit and check the wires for damage and repair as needed. BUT. this is best done by a vacuum repair man/person.
Dec 21, 2014 | Vacuums
Phone unlock code
As you have not specified in particular what is the unlock code required for you, i am giving the ways to unlock all the codes
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer care department.It is free of cost.
The restriction code can be got from your old service provider..This restriction code is kept to prevent someone who stole the mobile from using it with another provider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
Do not pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above procedure works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4979448-need_unlock_motorola_razor_v3_from_optus
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software...
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3079596-sking_puk_code
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
SECURITY CODE:
If you are talking about the security lock code to enter into the phone then once it is lost nothing can be done except flashing the mobile . Because if anybody can give the security code created then who ever who steals your phone can get into it and get your valuable information.
So as safety precaution to avoid that they have designed it such that if you forget the security lock you have to reset the mobile memory by flashing the mobile at an authorized service center.So while flashing the mobile all the data in the mobile memory will be lost and you can again start using the mobile.
Mar 27, 2011 | Vacuums
Cant get my rca remote to work on ,my sharp tv i need the code for sharp tv the model onmy remote is rcr311w
Not really sure what to do here, whether or not its a universal remote you are referring to. The attached is a link for almost any users manual for anything electronic. Hope it will help you find the users manual with the correct code. http://www.retrevo.com/support/HP-m8150-Desktops-manual/id/3167ag902/t/2/
Mar 21, 2011 | Vacuums
How to change a broken belt on a eureka surfacemax 300
Here is some info that will help:
You need this belt:
Eureka SurfaceMax 300 Belt
This is the manual with instructions:
Owner's Guide
Jan 02, 2010 | Vacuums
I have a hoover windtunnel u5757-900 and the motor stops in the mittle of the operation, no restrictions
when the motor stops, this is usually caused by an restriction in air flow...caused by a full bag, dirty filter or blockage. do you wait for about 30 minuites and it you can turn it on again? have you changed th dirt cup filter in the last 2 years? have you ever washed the dirt cup filter? if you have washed it, you should not have, however, once washed and dried the fibers would have expanded and will cause a restricted air flow condition.If all of this check ok, you may still have an electrical issue, and would recomend bringing that to a trusted Vac shop.
Jan 16, 2009 | Vacuums
Need owners manual for kirby ulitmate g series
Here is an online guide that will get you through the belt change process...you will also find manuals available. Hope this helps...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Jan 08, 2009 | Kirby Ultimate G Bagged Upright Vacuum
1957 Sunbeam Twin-Blade electric lawn mower shaft bushing
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=654762
Generic problem for all Vacuums
1957 Sunbeam Twin-Blade electric lawn mower shaft...
Posted by mower man on Jun 08, 2008
I have a late 50's series Sunbeam twin-blade electric lawn mower that I use regularly. The shaft bushing(s) on the left blade has worn out, and there's too much play for me to run it w/o ruining the machine.
It appears that the belt-run cog inside the housing is the part that is supposed to come off of the shaft to get to the bushings, but instead of a cotter pin or other fastener holding the cog in place, it looks like a rolled metal pin that may have been pressed in place.
How do I replace the shaft bushings so I can keep using this great vintage appliance!? I found a website that supplies parts for this model year, but no schematics or user manuals. Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. This website is for vacuums and you would need to contact a local lawn mower shop in the yellow pages, they are amazing about the way they can fix old lawnmowers.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Vacuums Logo
281 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
