Question about Canon MVX330i Mini DV Digital Camcorder
Tape carrage wont pop up - Canon MVX330i Mini DV Digital Camcorder
    Genius:
  • 1,812 Answers
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Apr 02, 2011
Can the Carrage be fixed or replaced on an HP DJ 6122 ?
yes you can replace the carrage buy that from any computer shop and they will fit it
Nov 18, 2009 | HP DeskJet 6122 InkJet Printer
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Tape carrage problem
Can I expect fixya rating with 4 blue diamonds now?
Jan 10, 2009 | Sony Handycam CCD-TR3300 Hi-8 Analog...
Tape jammed
sorry guys/gals problem was mechanical the riser carrage had jammed so used a big srew driver and mallet to get the tape out unscathed so problem solved thanks anyway.
Aug 17, 2008 | Canon Video Cameras
Hp 2115
issue with carrage , try cleaning ink carrage .
first
*unplug the power cable and press and hold power button for 1 min
*press and hold # and 6 , while holding # and 6 plug the power cable back in
*release the button after 10 sec
*wait for some time
*open carrage access door
*cleane printer carrage see for any dust in carrage
*pull the carrage to left
*turn off printer and turn it on
then try pressing OK and cancel at the same time
check for test page
Feb 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Tape compartment wont close and camera wont charge
You have probably blown the fuse which means sending to a service centre for repairs.
Jun 23, 2007 | Canon MV800i Mini DV Digital Camcorder
Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
Dvd player makes a ticking noisse and wont play
It sounds like you may have broken the DVD carrage which is drive by a motor and gear system. This could be as simple as putting the gear back on track or as hard as replacing the carrage itself. I would suggest that you get a qualified technician to perform this task because having some experience with this I have had to repair the carrage and laser assembly when folks tried to do this on their own. I hope this helps.
Feb 02, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
Canon MVX330i Mini DV Digital Camcorder Logo
43 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
