Question about Refrigerators
Ice maker freezes
I have tried all of the above. new icemaker, new double control valve. still freezes inlet line...hair dryer wearing out. any suggestions
  • 172 Answers
The only other problem that will allow the water to freeze would be a lack of water pressure. You can try to unhook the water line and turn the water on and run it into a sink or large bowl. You will be able to see if you have good water pressure. If the pressure is good, check your water filter. If the water pressure is low, you may need to call a plumber, or you can install a new water line. Good luck and sorry for the delay in the reply. I hope I was able to fixya. Mike
Posted on Sep 24, 2008
The inlet to my icemaker is frozen and wont make ice
Most likely your machine water valve is leaking water when not asked for water for the ice maker. This small amount of water will freeze inside that tube due to freezing temperatures inside freezer.
You may need to change the water valve assembly.
Try to use a heat gun (may be a hair dryer - be careful with water area) to slightly warm up the ice maker water inlet. You have to be very careful not apply direct too much heat. It is plastic and melt. Has to very slow and mild.
Oct 01, 2014 | Whirlpool Refrigerators
Ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jul 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 12, 2010 | Kenmore 57029 Side by Side Refrigerator
Water dispenser works but ice maker does not. Does not appear to get water. Where can I find the pump and how do I testit. Refrigerator is 2.5 yrs old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. It's on the back where the water supply connects to the fridge. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jan 24, 2010 | Refrigerators
Ice maker is not making ice, water flow line is good, how can i check to see if the line close to icemaker is frozen
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jan 22, 2010 | Refrigerators
We have a Maytag Refrigerator MSD2651HEW. The fill tube on the ice maker keeps freezing up. We have defrosted it with a hair dryer, but it will refreeze after a week or so.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips. Replace the water inlet valve.
Dec 19, 2009 | Refrigerators
Not pumping water to icemaker
Dec 08, 2009 | GE Freezers
Water not getting to icemaker. Shut off valve is ON
Oct 24, 2009 | Thetford Norcold RV Cooler/Freezer
Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Samsung RS2630WW Side by Side Refrigerator
The ice maker does not make ice anymore
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
thanks.
Aug 27, 2009 | Whirlpool Refrigerators
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
