Laptop turned off and wont turn on - Computers & Internet
  • 2 more comments
  • andyj758 Apr 02, 2011
    i have already tried to restart the laptop after charging the unit over night with no luck...the charging light does not come on even when plugged into the ac....have tried to start without battery in, with no luck and have held power button down without battery in, put battery back in after 10 minutes with no success
    my compaq nc8000 turned off suddenly even though plugged into the ac....have removed battery left it out for 10 minutes, held down power button and tried restarting with battery out...yellow charge light comes on and laptop sounds like it is going to start but after about 10 seconds it turns off....left plugged into ac overnight but charge light or ac light does not come on....
    this didnt help at all..no change
    i dont have a voltmeter...
  • 2,632 Answers
Welcome to Fixya. After removing the battery and charging it still won't turn on it seems that we need to check if the problem is caused by a bad AC adapter or Motherboard. If it will be possible to use a different working AC adapter to check if you will be able to turn on the computer. If you can then it means that its a problem with the adapter if not most likely this is a problem with the motherboard.
Motherboard Problem:
- It can be the AC adapter port or the mainboard itseft.
this is not a quick fix but If you still have warranty with compaq you can send the machine to a service center and fix it free of charge.
If you have questions please let me know. Thanks for using Fixya.
Posted on Apr 02, 2011
    President:
  • 1,961 Answers
There could be two reasons for your problem
1. Ac adapter is not making the connection, possible open wire on the cable, the plug / jack is not making the contact. If you have a multitester, try getting the output volts and compare to the actual output volts of the ac adapter. Try wiggling the end plug or the cable and see the readings in the tester. If the readings were not stable/ and or the output voltage drops then you will need a new ac adapter.
2. The battery is deteriorating, the battery can not be charged properly. Older batteries often develop internal shorts that makes it impossible for them to produce the voltage they're supposed to produce.
Check the voltage of the battery using the multitester - voltmeter, If the voltage out drops then replace the battery of the laptop.
  • 6,487 Answers
If a laptop wont power ON, this can be a power problem on your unit. First thing that we can do here now is to take the battery out from the laptop for about 30 minutes then after removing the battery try connecting the AC adapter to the laptop and see if there's any sign of light/life on it.
But if still wont power ON after 3 minutes put the battery back in and then charge the unit and after 1 hour try to power it ON and see if its fine now.
FUJITSU SIEMENS S6010 WONT TURN ON, HELP!!!!
Hi, I have alot of Motherboards for that Laptop. Maybe a New Motherboard Needed. CPU May have Burned out?
Email: microxtremecomputers@live.co.uk
Jan 28, 2010 | Fujitsu Siemens Computers & Internet
Laptop wont charge at all, or turn on
hey friend . .
this indicates that your battery is finished just go and buy new or
the battery need a repair . . . its charged is over . .
Oct 06, 2009 | Computers & Internet
My inspiron laptop wont turn on after I replaced
Verify that you obtained an exact replacement power adapter for the Dell. If it is an exact replacement then try this. Disconnect power adapter. Remove battery. Reconnect power adapter without the battery. If it turns on, then power off and place battery back in. Then try again. If problem returns, there could be a problem with the battery itself.
Sep 28, 2009 | Dell Inspiron B130 Notebook
My Dell Laptop D610 wont turn on. It was on, I
Turn off laptop, Remove the battery and the power cable and press the power button for about 30 seconds.
Check for light on AC adapter.
Try with battery alone. Try with AC adapter alone.
Try with a different adapter of the same kind.
else the issue could be with the main board for which I would request you to contact the manufacturer.
Sep 11, 2009 | Dell Latitude D610 Notebook
My screen wont turn on
Hiya, have you tried plugging in an external monitor to the Blue VGA port of the laptop ?
If so, do you get any display then ?
Hint : you need to plug in the external display 1st, then turn on the laptop. If the External monitor doesn't come on, then you may need to press the Function key on the laptop & the F4 key (Or whichever shows a monitor logo) to get the laptop to switch to external monitor.
If you CAN get display on the external monitor then the problem could either be that the Invertor for your laptop screen has blown, or, the backlight for your Laptop Screen has broken, or the Laptop screen itself has gone faulty. In rare cases, the cable from the Laptop Motherboard to the screen may be faulty or have come away form the connector on either end.
Hope this helps.
Mar 19, 2009 | HP Compaq Presario F750US
My laptop will not turn on and the power light blinks amber
it does not display anything when you try to turn it on?
Dec 16, 2008 | Medion (40010998)
Turn LAPTOP ON
push the screen to you and push it away so far as he can.
you hear a click the screen is fixed
May 14, 2008 | HP OmniBook XE3 Notebook
Wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Apr 05, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
