Question about Dell Latitude D620 Notebook
What is the maximum capacity of hard disk (hdd) does dell d620 supports and, does dell d510 supports SATA hard disks
    Genius:
  • Dell Master
  • 1,479 Answers
The d620 should really accept any internal drive you can physically fit inside, the only issue might be the bios but anyrecent machine should be ok. No, the d510 does not appear to support sata drives. Just take the old one out to check, if it has a load of pins on it then definitely no. (sometimes dell use their own single finger adapter on the pins - sata drives have two fingers)
Posted on Apr 02, 2011
My HDD will going to corrupt, so i need to buy one, but i don't know that which HDD is compatible with my AMD Athlon XP 2000 PC. Could any one suiggest that how much maximum capacity HDD Support my PC....
Hard Disk upto 500GB capacity can be added to most of the PCs. As regards compatibility, first you have to check the motherboard for SATA Hard Disk interface as newer hard disks are SATA. Adding the hard disk has nothing to do with the processor. However, motherboard should have the connecting port/ option (such as SATA). Some motherboards support both IDE and SATA devices. Please check the motherboard for SATA Port. You may find the motherboard model/ system model and google a bit for its specification. (You have mentioned AMD Athlon XP 2000, which is the Processor not the motherboard)
If SATA is available on your motherboard, you may add Sata drives of 250-500-750GB drives according to you requirements. Otherwise you have to look for IDE hard Disk.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | AMD Athlon XP 2000+, 1.67 GHz Retail...
My HDD does not detect its complete capacity, it works just with 7.87 gb when must be 1tb, I would please you so much if you know something about this hdd problem. Thanks!
Many, many, years ago, motherboards did not support any disk-drive larger than 8GB.
Is this the first time that you have tried connecting your 1000GB disk-drive to your computer?
Apr 02, 2011 | Samsung Spinpoint F1 HD102UJ 1TB 7200 RPM...
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
What is the maximum size of hdd to used with abit kv7
Good day sir/maam, yes you can use a 1 TB HDD, get the SATA version depending on the bios but im not sure it be compatible with SATA1 on your motherboard, any new hard disk canor cant be read by any old motherboard, you may have problems with SATA versions, there are 3 versions, but the problem is the response of the hard disk. The rule of thumb, fast motherboards, for large hard disk, because it can access large amount of data very fast usually they are SATA3. So slow motherboards with large hard disk is kinda slow, you be bored. I suggest you stick on the recommended hard disk. If you want extra storage, get 3 hard disk and daisy chained them as master/slave.
Oct 14, 2009 | Abit : KV7 Socket A KT600 Motherboard
How many GB hdd does intel 945GCCR support
Depends on how your formatting this sir.. The bios first would need to support large drive or LBA mode if it does you need to format this using NTFS file system or FAT 32...
Oct 03, 2009 | Intel D945GCCR Motherboard
Sata HDD very slow
Dear friend you need a sata board to get maximum speed of sata driver connect it directly to motherboard sata jack converter does not give full sata speed
Jul 22, 2009 | Hitachi Deskstar T7K250 250 GB Hard Drive
500 GB SATA HDD Not Showing in Windowss 2000 Server Plat form
Reset your Cmos
And go into bios and search for a hidden partition
Sep 23, 2008 | Microsoft Windows 2000 Professional for PC
Hdd installation
The capacity that a motherboard can support is designated by the BIOS.... a few years ago when HDDs started to get big, there was an issue in supporting disks above 137GB as this exhausted the old HDD addressing system..(BIOS), to rectify this the BIOS code was re-written to support 48bit LBA (Logical block addresses) so as long as you have up to date BIOS for this motherboard, it should be alright.
you should be able to install any capacity available on IDE as long as you have updated the BIOS to the latest version (check the Giga byte website to download this)
If you wish to upgrade your PC further you can get a SATA/PATA adapter, or you can get a PCI SATA, IDE or SCSI controller card. Effectively there are very few limitations to the number of disks nowadays.
Dec 05, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Dell Latitude D620 Notebook Logo
518 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
