Question about Dishwashers
My mother-in-law has an old Service Secret compact dishwasher. Last time we tried to use it, it started a cycle and when we returned to it the red light was on to say the cycle was finished but the dishes were still as they were when they went in. She's checked there's salt (hard water area) and yes there was a dishwasher tablet in!
  • 11 Answers
SOURCE: DISHES COVERED IN WHITE POWDER
To check on the source of the white powder (calcium?) soak some dishes in vinegar to see if this cleans them up nicely ... or if the 'white powder' is actually permanent etching. You may have very 'hard' water and will need to deal with that with a water softener or additives.
Read the following article for a better understanding and try the vinegar test . (also ensure you are using dishwasher specific salt to regenerate your integral softener... assuming you have one)
http://www.dishwasher-care.org.uk/best.html
Posted on Nov 02, 2007
  • 677 Answers
SOURCE: Dish Washer
the problem is not the dishwasher but the water that actually is going into it. the white, powder substance is because of hard water. there is a affordable product out there called the dishwasher filtration system. it will filter the water going into your dishwasher and solve the problem once and for all!!! it is affordable and easy to install. www.dishwasherfilter.com
Posted on Feb 09, 2009
woodchuck789
  • 4066 Answers
SOURCE: Glasses not clean and shiny
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Posted on Jul 06, 2010
SOURCE: I have a nardi dishwasher
nardi dishwaser water will not drain away after wash cycle.
Posted on Sep 08, 2010
heatman101
  • 43501 Answers
SOURCE: not cleaning properly
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
a43mc
Posted on Sep 29, 2010
My haier dishwasher won't drain. It's new ( used 3 times ). It has never drained properly according to mother in law. Didn't drain last night ( no dish cycle ) , pipes and filters all clear of debris.
Two things that you can try. One is to get a wet and dry vacuum and hook it to the drain hose and see if you can vacuum any water out. You should be able to. The other thing is to see if you can force water in with a garden hose. If memory serves me the pump has a valve on it and the valve might not be opening. It could be the valve or the power to the valve.
Dec 16, 2012 | Dishwashers
Incessant end of cycle beep. Can I stop it? My new Bosch shx68p05uc drives us nuts. My 88 year old mother-in-law sleeps near the kitchen and I cannot run this dishwasher at night due to this darn...
Welcome to FixYa.
To turn the volume down of the signal or to turn it off entirely is as follows...
Hope that solves your incessant beeping problem. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided here as well as a brief testimony is appreciated.
Regards,
Macmarkus :)
Apr 19, 2011 | Bosch SHX68P05UC Dishwasher
Cycle time
yes its normal.bosch dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Not starting
Getting Started
1. Load dishwasher (See Preparing and Loading Dishes).
2. Add detergent (See Dishwasher Dispenser & Detergents).
3. Add rinse aid, if needed (See Rinse Aid).
4. Close door to latch.
5. Select desired CYCLE (See Cycle Chart).
6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
8. To start, press START/CANCEL pad.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher - excess suds
you mean dish sink soap lol just keep running it till its gone with out dishes may take three cycles not the first time ive seen this leave the door closed and get a mop sorry my mother in law did the same thing
Jan 15, 2008 | GE 24 in. Profile PDW9200J Built-in...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
