I want to use my lcd screen as my monitor, i put the cable in the dvi input on my lcd, but nothings happening
    Problem Solver:
  • 6 Answers
Try composite video RCA socket
Posted on Apr 02, 2011
My LG E2250V-PN turns on and my Macbook goes to a blue screen, indicating that it is picking up a signal, but then nothing happens. My Mac screen never shows on my LG. Also, even if i try to press the menu...
Hi sophie,
I see you want to extend you monito to an LG external monitor.
Have you tried selecting the input PC or the input that is for the cable that you are using for the Video.
If you are using HDMI select the Input HDMI on your LG if you are using DVI then you should select the input DVI to be able to get the signal from the Laptop come out of your LG.
I hope this helps.
Have a nice day,
mvincentc
Jun 25, 2011 | LG E2250V-PN 21"LCD Monitor
Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
Sep 21, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
I have HP Pro3000MT, and it has vga and dvi port. I want to use dual monitor for this pc. the monitor are HP LCD and it only has vga input. first i use vga port, secondly i use this dvi cable to connect to...
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Apr 01, 2011 | HP SmartBuy Pro 3000 MT Pent Dual Core...
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
2yahoo.co.inhow to attach this to dvi desktop
Does your computer's video-card have a DVI-output socket?
Does your LCD monitor have a DVI-input socket?
If 'yes' to both, then you need a DVI-to-DVI cable.
Does your LCD monitor have a VGA-input socket?
If 'yes' to both, then you need a DVI-to-VGA adapter,
and a VGA-to-VGA cable.
Oct 23, 2010 | ViewSonic VG900b 19" LCD Monitor
DVI-D cable not working with Westinghouse L1975NW...
If the monitor has two video inputs - a DVI-D and a DSub VGA then the monitor needs to be switched to the DVI-D video input.
Jan 26, 2010 | Westinghouse L1975NW Monitor
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Put an adaptor on my cable and the monitor screen goes blank
Hi Kathy,
Nothing you can do, it could be the laptop does not understand Digital Video Interface DVI
What is the laptop make / model?
Mar 13, 2009 | ViewSonic VA1912wb 19" LCD Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
