Question about Westinghouse Refrigerators
JUST WANT TO CHANGE THE LIGHT - Westinghouse Refrigerators
  • Westinghouse Master
  • 3,740 Answers
I am assuming we are talking about a compartment light. Most every brand the light over has lock in tabs that you release with your fingers by GENTLY squeezing the light bulb cover from one side. Only one side will unlatch. The other side is locked and you have to pivot the cover to about a 40 Deg angle to remove it. Grip the socket so it does NOT flex, unscrew the bulb and install the new bulb. To reinstall the cover... tilt it to align the locked tabs and then GENTLY squeeze the cover again to engage the last 2 tabs.
If you need model specific information we need your model number please. The information above should help you accomplish the light bulb change.
Thanks for choosing FixYa,
Kelly
Posted on Apr 02, 2011
Rs4 manual
Are you asking how to change the light itself? or how to change the auxiliary button ? ie when you turn on the pool light does the spa light come on?
Aug 05, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Check engine oil light flashes after oil change
Do you mean oil change warning light or oil pressure warning light?
Feb 04, 2013 | 1999 Volkswagen Jetta
How to reset the change oil light on 2001 chevrolet suburban LS
Turn the ignition key to on position, but do not start the vehicle.
Wait for the "change oil light" to come on
Tap the throttle pedal three times quickly
Wait for the light to flash several times, then go out.
Start the car and drive and it won't come back on.
It usually works the first time, but repeat if light stays on.
Jul 28, 2012 | 2001 Chevrolet Suburban
How do i reset the oil change light in a 2003 olds alero
turn key on (dont start engine) floor gas pedal 3 times 1,2,3. turn key off, now start engine it should go off, if not try it again.
Aug 03, 2011 | 2003 Oldsmobile Alero
How do i reset the waterfilter light
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
If you have other questions please let me know, Thanks Sea Breeze
Jun 10, 2011 | Jenn-Air JCD2389G Side by Side...
Why are my service vehicile soon lite,brake lite, antibrake lite, and change oil lites on after i start car
service engine light------scan for codes
brake light and antilock brake light ----abs problem scan for codes
change oil light ----- change oil and reset system light
May 21, 2011 | Oldsmobile Alero Cars & Trucks
How to reset the change oil light for lincoln town car 2007
Press setup on message center,
press select for system check,
At oil life, press reset
Aug 14, 2009 | 2007 Lincoln Town Car Signature Limited...
My oil change light is still on, but I got my oil change and the light is still on. How do you reset the oil change light?
turn ignition switch to on or run position with engine off press accelerator pedal slowly to wide open throttle 3 times within 5 seconds change oil light will flash 5 second if not retry
Jul 13, 2009 | 2003 GMC Envoy
Oil change light stays on after oil change
1. Turn ignition switch on but don't start the engine. Push ENG MET button on the trip monitor ONE time.
2. Press ENG MET one more time within 5 seconds. Within 5 seconds press and hold the RANGE button (90-94) or the GUAGE button on 95 Vettes, you will see the light start to flash
3. When light stops flashing the CHANGE OIL LIGHT has been reset
Apr 21, 2009 | Chevrolet Corvette Cars & Trucks
Change oil light reset?
Hi Shady, here is the procedure for resetting the light.
Resetting Procedure
Follow this procedure to reset the GM Oil Life System™
  1. Turn the ignition to RUN, with the engine off.
  2. Fully press and release the accelerator pedal three times within five seconds.
  3. If the CHANGE OIL SOON light flashes, the system is resetting.
  4. Turn the key to OFF after the light has finished flashing, then start the vehicle.
  5. If the CHANGE OIL SOON light comes back on, the engine oil life system did not reset. Repeat the procedure.
With Trip Computer
  1. Press the MODE button until the light appears next to OIL LIFE.
  2. Press and hold the RESET button for three seconds. The oil life percentage should change to 100 percent.
Nov 02, 2008 | 2002 Pontiac Grand Prix
Refrigerators Logo
213 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
