Watches Logo
Posted on Apr 02, 2011
I need to reset the time - Casio Watches
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Apr 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
Helped
901
Points
19
Not sure if all Casios are the same but mine works like this.
Push bottom left button 3 times until Seconds digits flash. Adjust Seconds by pushing or holding in bottom right button. Push in top left button to move to Hours ( will flash } Adjust as for Seconds.
Push in top left button to move to Minutes, adjust then move on to Date, etc.
Push bottom left button at any time to return to normal. Good luck!
Amana side by side display flashing for date/time, but buttons don't work.
Most don't automatically reset. If the appliance has a reset button, it should just need to be held in for 30 seconds to correct the fridge. Some refrigerators, including Maytag and Amana, need to have the lock button and the reset or auto buttons held at the same time to reset the fridge
Jun 15, 2020 • Watches
1helpful
I have a Coleman digital watch. Four button. I replaced the battery and need to reset the time and date.
Click on your watch model number to open the instruction sheet below.
Your model number is located on the caseback of your watch
go here> http://www.gsi-usa.com/instructions/
4helpful
Need to reset the time. Side knob will not pull
Is it a pull out or a screw? My Breil 0080 is a screw... when i first got it, i couldn't pull it out either. Try turning it counter clockwise.
Apr 06, 2010 • Watches
Resetting the Analog time on my Citizens Stars and Stripes Watch
I couldn't find find your model on their web site but if all else fails, you could go to "www.citizen-signature.com/#/support", where you will be able to request instructions.
Mar 11, 2010 • Watches
After replacing battery, the watch does not
I found and pressed the reset button with a tiny screw driver. After about 10 attempts, I pressed the function side button and found that date and time displayed temporarily while holding button down.
Finally after more reset attempts, the time did display.
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
