Question about HP EliteBook 6930p Notebook
I am not able to connect my laptop to tv using vga to rca. But it is working when I connect another monitor to vag directly. Waht hould I do to overcome the problem?
  • 3,400 Answers
You need to change channels on TV or set an AUX input (on TV)
Posted on Apr 02, 2011
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
How to connect my dell inspiron 1501 laptop to my hdtv. am using a vga cable with rca out, to connect to the tv. i have tried everything but none works. if this can work please sent me step by step...
1 - the cable you are trying to use will not work - the RCA inputs in your tv can't accept the signal coming from the VGA. To connect the laptop to a tv the tv must have an VGA input, nothing else will work.
2 - When you start the laptop with an external device (such as an external monitor or tv) attached and turned on, the image may appear on either the laptop's display or the external device.
Press to switch the video image between the display only, the external device only, or the display and the external device simultaneously.
Apr 27, 2011 | Dell Inspiron 1501 Notebook
No problem, wondering if I'm able to connect this TV to my laptop to connect to the internet and if so what do I need to do this.
Yes, you should be able to. You will need to buy a $20 adapter. Sewell Direct sells them, also Amazon.com. They are called VGA to RCA composite video converter. This will convert your laptop's VGA output to RCA composite video for connection to your TV yellow video input. Connect an audio cable from laptop's earphone output to the TV's RCA audio inputs (white and red) using a 3.5mm to RCA adapter cable available at Radio Shack for about $10. This will work. You can see everything that the laptop displays on the TV. You can even hookup a VCR to record it all.
Aug 04, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Can i connect my acer aspire 4730z to my television so i can watch dvds
Yes of course.
First of all you will need to identify the available input ports on your TV. An RCA port is generally standard nowadays and it consists of a red, a white and yellow coloured reception ports (the colours may differ between tvs, i.e black instead of red). The red and white are for stero sound and the yellow is for video.
Modern TV systems also have a VGA adapter which is small flat port like the ones on a computer screen. This is usually blue.
A third option is an S-Video port, which is round in shape.
To connect your laptop using the RCA port, you will need an S-Video to RCA converter. You connect the S-Video to the port on your latptop, and through the converter to the RCA yellow port on your TV. For sound you will use another cable that connects to the headphone jack on your laptop and then splits to a white and a red cable to connect to your TV.
If you have VGA port on your TV, then connect the VGA port on your laptop to the VGA port on your TV. No converters needed. For sound you will use the same approach as above.
To use the third option you will need to have an s-video out port on your laptop and you will connect it directly to your TV s-video port. For sound, again you will use the approach as the rca solution.
Then, using your remote control, select the AV mode or depending on your TV select the PC or VGA mode.
Finally, to transfer the video from your laptop to your TV press and hold the Fn key on your laptop's keyboard and then the F7 or F9 key. (It has s small TV icon on it).
That's it!
Regards,
nicolasiac
Apr 08, 2010 | Acer Aspire 4730-4947 Notebook
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
Connect to a tube TV
hi mr. pavilion dv6700z. i have the same problem before but after i tried and use my genius mind. i made it. and the television is working in my laptop as a external monitor. pixel is good. just connect in card video out to video iput to television. romsky79@yahoo.com.
Jun 06, 2009 | HP Pavilion DV6700Z Notebook
How to connect acer laptop to philips tv to use tv as monitor
If your TV has a VGA input you can connect the laptop using a standard monitor cable. If the TV has component video inputs, you can get an adapter cable with a VGA plug on one end and the appropriate RCA plugs on the other.
Without these inputs, you can't connect the laptop directly. You will need a converter to switch from the computer's VGA output to a standard video signal to feed to the TV. Here is a website with a sample converter. (I don't know this site. It's just one I picked from a Google search as an example.)
Mar 23, 2009 | Philips Televison & Video
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
HP EliteBook 6930p Notebook Logo
205 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
