Question about Karcher K3.68MR Electric Pressure Washer
Hi, I have a Karcher K3 pressure washer. 18 months old, used maybe 6 hours total. For the past 3 hours of use the compressor/pump seems to cycle audibly but pressure at outlet hose seems constant, hence I did'nt worry. Now it does not start with switch on. I now hear a buzzing sound from the unit. The unit was last used 6 weeks ago. The unit was stored in the garage away from frost, it does not leak water so I don't think there is any frost damage, but just this buzz. Any suggestions would be much appreciated. Thanks Dave
CaptAdams35
  • 28 Answers
SOURCE: karcher power spray frost damage
I've found the most useful repair people for power washers are lawn mower repair techs. Give them a ring and see if they do house calls, they'll be your best bet.
Posted on Mar 09, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I can use my Karcher K3 jet wash as long as i hold trigger down
Most pressure washers have ball lock type fittings on the hose connections. What happens is the little steel balls get a bit of corrosion and do not lock the male fitting properly with the female coupling. Load up the fitting with some Oil or WD 40. Then connect and disconnect the fitting several times to losen up the balls and springs. Should the spring in the coupling break you will get the exact symptom your describing.
If the OIL / WD 40 does not do the trick then you may have to change out the quick disconnect coupling.
Kelly
Posted on Apr 18, 2010
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
SOURCE: Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Posted on Jun 14, 2008
SOURCE: karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Posted on Jul 16, 2008
Karcher k 3.99 does not pause correct
Is there a water leak from the bottom ?
Is so, then there maybe a small crack in the seam of the plastic manifold pump housing or one of the connecting fittings. A New Manifold Complete about $61.00. You may purchase direct from Karcher, and replace if you are mechanically inclined.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
May 09, 2010 | Karcher K 5.85 M Electric Pressure Washer
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
May 03, 2010 | Karcher K 5.85 M Electric Pressure Washer
Kelly
Apr 18, 2010 | Karcher PSI Electric Pressure Washer
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Is there a water leaking from the bottom ? If so then there maybe is a small crack in the Pump Plastic Manifold Housing. A New Manifold Complete Replacement is approx. $61.03 from Karcher, if you are mechanically inclined.
If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Mar 16, 2010 | Karcher K 5.85 M Electric Pressure Washer
How to connect the cold water supply to K 3.65 Jubilee? In the instruction leaflet, figure J, number 1, 2, and 3 I seem unable to connect it. The above is a pressure washer.
Hi all you need is a 3/4 tap fitting from a diy store.
Maybe a hoselock 3/4 male and female fitting that will fit a standard 1/2" hosepipe. If struggling I can send you a link to the fitting on ebay but if you type in karcher tap connector you will see it by the seller vavcandwash.
Feb 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Hesistation on pressure when trigger is pulled get n worse
Unloader valve is the most likely suspect here.
Remove and clean with penetrating oil then reinstall.
Also add some LIGHT oil into your supply hose via a small funnel. 3-in-1 household oil or power steering fluid lubricate the valve and pump quite well. Three or four treatments of a couple ounces each will usually make the pump happy again. If this unit has an OIL-FILLED pump on it you can expect good results. If it runs an OIL-LESS pump it is only rated for about 100 total hours of life!
Hope this helps.
Sep 26, 2009 | Honda Karcher G4000RH Pressure Washer
I have a K3 78M electric unit . The motor pulsates
This sounds like an internal leak. If you are handy enough here is a schematic. On B@ it could be #25 is sticking or the valve inside #8 is leaking or the water seals #18 need replacing or #1 is leaking
Aug 18, 2009 | Karcher Garden
Excell VR2522 Pressure washer - sudden loss in pressure.
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
Jun 18, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K3.68MR Electric Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
